It is currently Thu Apr 02, 2026 12:55 pm
Reply to topic  [ 9 posts ]
 EFI starting time
Post EFI starting time
I have a MB 37 EFI and I feel it takes a longer to start than it should. My fuel take is located up front under the deck. Is this a common problem with gas tanks located in the front of the boat? I understand the fuel pump may have to suck quite a bite before it is primed. It starts a little better but not much more after it has been running for awhile. Motor runs great and ideals fine so I am confident it has nothing to do with the fuel pump. This is my first mud motor so I have little experience with them or Mud buddy, but My buddys carbed pro drive fires right up as soon as the key is turned over. I went from a carbed mercury 3 cylinder 2 stoke that would fire by just looking at the key once the primer ball was firm.
Mon Nov 07, 2016 7:19 pm
Post Re: EFI starting time
Why not try turning on the key and allowing the lift pump time to prime before cranking? That's how I've always done mine and it starts every time in just a couple revolutions. When it's warm, even faster. Takes maybe a second or so for the pump to prime. Easy.
Tue Nov 08, 2016 12:08 am
It has to turn over at least twice for the ECU to decide when to fire. How many revolutions does it turn before it starts?
Tue Nov 08, 2016 12:28 am
Try disconnecting the low oil pressure sending unit.. See if it starts any better...
1754 With Level 3 GTR
Tue Nov 08, 2016 8:17 am
on a cold start it probably takes 10 seconds or longer to start.
Tue Nov 08, 2016 7:53 pm
Stu is correct. I would start simple and check all your fuel line connections from the filter at the lift pump to the tank.
Wed Nov 09, 2016 7:16 am
I believe mine starts quicker if it let it prime up and stop before turning it over. After that maybe 3-4 revolutions to start. Once hot, starting seems almost instantaneous.
MoMarsh Fatboy/2 Honda
Thu Nov 10, 2016 6:29 am
It is always good to allow the rail to prime before cranking the engine. It only take 2 seconds.
Thu Nov 10, 2016 6:40 am
sounds good fellas, I will try try that. I am usually in to big of a hurry and just want to crank it and go.
Sat Nov 12, 2016 11:50 am
