| PRODRIVE will Not Crank http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=68905 |
| Author: | JJDTodd [ Sat Nov 12, 2016 1:48 pm ] |
| Post subject: | PRODRIVE will Not Crank |
Was running up the river today and killed my my motor to stop and see what the morning flight would be. When I went to crank it back it died and now it will not even turn over or try. When I turn the key the fuel pump turns on but nothing after that. I have made sure the kill switch was properly in and that the clutch was disengaged. I need some help. It seems like a ground or a fuse but I haven't found an issue with them. Sent from my SM-G928V using Tapatalk |
| Author: | 50fps [ Sat Nov 12, 2016 5:43 pm ] |
| Post subject: | Re: PRODRIVE will Not Crank |
Check the main harness connection down by the starter for corrosion. |
| Author: | cledet [ Sat Nov 12, 2016 8:48 pm ] |
Had a similar problem a while back and it turned out to be a bad PTO switch. |
| Author: | JJDTodd [ Sun Nov 13, 2016 7:51 am ] |
| Author: | ibfishinb [ Sun Nov 13, 2016 8:17 am ] |
EFI? Sent from my SM-G920V using Tapatalk |
| Author: | cledet [ Sun Nov 13, 2016 9:20 am ] |
| Author: | JJDTodd [ Sun Nov 13, 2016 10:37 am ] |
| Author: | Quackhead62 [ Mon Nov 14, 2016 2:47 pm ] |
Mine did the same thing last year it was the key switch. Changed it out and ran like a champ. Sent from my iPhone using Tapatalk |
| Author: | JJDTodd [ Mon Nov 14, 2016 8:04 pm ] |
Ended up being a bad starter and solenoid connection Sent from my SM-G928V using Tapatalk |
| Author: | dead animal [ Mon Nov 14, 2016 9:37 pm ] |
yep, that will make it hard to start!!!!!!!!!! |
