It is currently Sun Apr 12, 2026 11:51 am
Reply to topic  [ 11 posts ]
 PRODRIVE will Not Crank
Post PRODRIVE will Not Crank
Was running up the river today and killed my my motor to stop and see what the morning flight would be. When I went to crank it back it died and now it will not even turn over or try. When I turn the key the fuel pump turns on but nothing after that. I have made sure the kill switch was properly in and that the clutch was disengaged. I need some help. It seems like a ground or a fuse but I haven't found an issue with them.
Sent from my SM-G928V using Tapatalk
Sat Nov 12, 2016 1:48 pm
Post Re: PRODRIVE will Not Crank
Check the main harness connection down by the starter for corrosion.
Sat Nov 12, 2016 5:43 pm
Had a similar problem a while back and it turned out to be a bad PTO switch.
18' x 54" Uncle J Custom w/ PD 36 FPR and Calen's Stage 2
Sat Nov 12, 2016 8:48 pm
Sun Nov 13, 2016 7:51 am
EFI?
Sun Nov 13, 2016 8:17 am
Sun Nov 13, 2016 9:20 am
Sun Nov 13, 2016 10:37 am
Mine did the same thing last year it was the key switch. Changed it out and ran like a champ.
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Mon Nov 14, 2016 2:47 pm
Ended up being a bad starter and solenoid connection
Mon Nov 14, 2016 8:04 pm
yep, that will make it hard to start!!!!!!!!!!
Mon Nov 14, 2016 9:37 pm
