It is currently Mon Apr 06, 2026 5:27 pm
[ 2 posts ] |
Adjusted governed on 36pd now wants to rev on its own help
Midnightsun
New Member
I adjusted the governed on my 07 prodrive now my t wants to rev up on its own any help
| Wed Nov 16, 2016 1:10 am |
banded-mallard
 Re: Adjusted governed on 36pd now wants to rev on its own he
You adjusted too much, you need to dial it back some. I had an 07 briggs on mine before swapping to a Kawasaki. You need a stiffer spring that will allow you to adjust more. Prob is, they are like trying to find a needle in a haystack. So this is what I did. Take your governor spring off, should have several wound coils. I used some SS wire, but you can use a tie wrap also. Take about 4 coils of the spring and wire or tiewrap them together. Thus making the spring stiffer. Before I did this, mine would adjust past 4600, after stiffening the spring, I could spin to 5000+ with my then stage 2. So you need to adjust the govnor back so that the engine idles normal, then do as I did above.
| Thu Nov 17, 2016 5:21 am |
[ 2 posts ] |
