How to convert tapered shaft to straight
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=69037
Author:  DrakeHunter [ Wed Nov 23, 2016 8:36 pm ]
Post subject:  How to convert tapered shaft to straight
Hey have subaru generator with tapered shaft that I may put on a surface drive if there is a way to convert/adapt to a straight shaft. Thanks in advance.
Author:  fjreinke [ Thu Nov 24, 2016 5:39 pm ]
Post subject:  Re: How to convert tapered shaft to straight
Author:  brycecheramie [ Thu Nov 24, 2016 5:49 pm ]
The only thing I have seen on here, the guy pulled the shaft, and had it welded up, then cut to be a straight shaft. Seems to me like the cheapest/ easiest thing to do.
Author:  Will C [ Thu Nov 24, 2016 6:42 pm ]
Yea he had a good machinists buddy
Author:  banded-mallard [ Mon Nov 28, 2016 6:16 am ]
I remember seeing an adapter that can convert a tapered to a straight. It basically slides over the shaft and is held in place with the bolt at the end of the crankshaft and uses the existing keyway.
Author:  banded-mallard [ Mon Nov 28, 2016 6:26 am ]
similar to this. Just need to find your correct size.
Author:  igotit [ Mon Nov 28, 2016 7:43 pm ]
As stated i opted to pull my shaft and have it machined.
The best option is a new crank for $6-800,but at that price i could find a similar engine used with the standard crank already in it.
So 2 other options.....gamble on that cheap taper adaptor,or machine shop.
Id pass on the adapter,to me it has failure written all over it.
On a gokart application....id gamble with it.but for a boat i may take on a 10 mile trip into marsh.....no gambling for me.
Just my opinion.
viewtopic.php?f=6&t=68387
Author:  brycecheramie [ Mon Nov 28, 2016 8:18 pm ]
Dat be it!! ^^
It looks damn good too
Author:  igotit [ Mon Nov 28, 2016 8:27 pm ]
Thanx....best option in my opinion,machine shop woulda charged around $100 to do that job.
Made a new gasket for base.
Author:  50fps [ Tue Nov 29, 2016 8:20 am ]
Machine shop rates must be pretty low in some areas. Up here that would be the first hour of labor.
Author:  igotit [ Tue Nov 29, 2016 12:44 pm ]
$85-100 per hour average in houma,1 hr minimum....didnt take long.
