It is currently Sun Apr 05, 2026 11:53 pm
Reply to topic  [ 2 posts ]
 mikuni carb help
Post mikuni carb help
Well I needed to clean my carb cause it was gummed up with bad gas from setting (back injury ) anyway I've got everything cleaned but the slide won't return from the spring tension haven't had to get into this part of the carb before so I thought I'd ask for some advise on best way to proceed getting it to retract after pull in the throttle thanks for any help :) :)
Fri Nov 25, 2016 6:48 pm
Post Re: mikuni carb help
Problem solved itself I cleaned it with carb cleaner and it wouldn't slide for shit left it sitting on the bench for couple hours went back to check it and it was back to normal slid just fine weird
Fri Nov 25, 2016 10:01 pm
cron
