It is currently Sun Apr 05, 2026 10:24 pm
[ 4 posts ] |
25hp Kohler GDLT charging circuit issues.
redlined_b16a
Bought it used would not charge battery.With an meter the stator only put out 13volt a/c its requires 25-40 volt a/c.
Ordered a new stator and voltage regulator. Removed flywheel to change stator and found all magnets broke and unglued. Luckily I kept magnets from some early 1980's kohler.Re glued in correct order,installed new stator and 3600 rpm produces 44 volt a/c current. With my black lead on negitive terminal on battery and red lead on the B+ terminal of voltage regulator It reads -3 volts d/c. I looked at several kohler wiring diagrams and my harness is not connected like others show.Kohler harness for mowers show the b+ connecting to key switch/wire for fuel soloniod. When I done that my meter read 21 volt d/c going to batter. Currently the b+ wire is hooked up to the positive battery lead on starter solonoid,Hooked up this way the battery gets a half volt charge increase.
I dont remember what I did but I was able to get 14 volts from b+ wire but it was reading -14 volts as if I had my meter leads backwards
I emailed GoDevil but it is the holidays. Does anyone have experince with this wiring or has a proper diagram?
Thanks
| Tue Dec 27, 2016 8:16 am |
Will C
 Re: 25hp Kohler GDLT charging circuit issues.
Do you have a ground wire from the regulator screw to and engine mount bolt?
| Tue Dec 27, 2016 9:58 am |
redlined_b16a
Yes it has the ground wire and I went as far as mounting the regulator directly to grounded metal shroud. A member here just sent me a wiring diagram.Im at work now but my B+ wire is routed to the start solonoid as the diagram indicates.
| Tue Dec 27, 2016 11:07 am |
redlined_b16a
When I wire B+ like GoDevil states I get 21 volts dc to battery. Wired like Kohler states I get -3 volt,however it does charge battery a lil. I still have to wait until I get time to completly trace harness. Godevil diagram
Kohler diagram.
| Wed Dec 28, 2016 8:10 pm |
[ 4 posts ] |
