| Go Devil Q about the big bushing between steering plates http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=69409 |
| Author: | Bayport [ Sun Jan 01, 2017 7:36 am ] |
| Post subject: | Go Devil Q about the big bushing between steering plates |
Called GD but they are out for holidays so thought I'd ask here. Looked at the manual but nothing there wrt replacing it The main steering/pivot bushing is worn out. It's between the steering plates with a big bolt thru it. Anyone ever change that out? Looks like you would attach the engine to a hoist, unbolt it and lift the engine and insert a new bushing, though not sure how that gets inserted. Appreciate any info. Thanks, LT |
| Author: | Bayport [ Thu Jan 05, 2017 8:01 am ] |
| Post subject: | Re: Go Devil Q about the big bushing between steering plates |
Talked to Warren at GD. Said to replace the bolt which will take care of about 50-60% of the slop. Seems to have done the trick. |
| Author: | kirk [ Thu Jan 05, 2017 5:06 pm ] |
| Author: | Will C [ Thu Jan 05, 2017 9:16 pm ] |
When the holes get real sloppy you can weld large washers the size of your bolt to the flapplate and frame. Then use a little longer bolt. Makes it goodntight |
| Author: | Bayport [ Tue Jan 10, 2017 7:32 am ] |
its a 2005 I believe. Yea, Warren mentioned about welding on some pieces. Changing the bolt helped a lot. I was thinking of looking for a metric bolt that was a bit larger than 2/4 but it's good for now. |
