It is currently Sun Apr 05, 2026 10:24 pm
Reply to topic  [ 8 posts ]
 Timing Key Install
Post Timing Key Install
Looking to install an advanced timing key, when re-torquing the flywheel nut, what is the best way form stopping the shaft from spinning.
I had put a piece of wood between the prop and cavitation plate last time two problems, sheered the key so I must not have it it torqued all the way and i bent my cavitation plate. Next project will be trying to straighten that out.
Tue Jan 03, 2017 3:58 pm
Post Re: Timing Key Install
I'm about to get into this with the engine off the frame. I could use some advice on this as well...
1438 Jon / 23hp MBLT
Wed Jan 04, 2017 8:57 am
Impact gun!
Wed Jan 04, 2017 10:07 am
Wed Jan 04, 2017 10:30 am
1 1/4" socket correct? (23hp)
Wed Jan 04, 2017 10:53 am
So some debate on the impact gun, but when torquing the nut how do you best stop the output shaft from just spinning?
Wed Jan 04, 2017 1:39 pm
Fly wheel tool. It grabs the teeth to hold it. Its an automotive tool.
Wed Jan 04, 2017 2:15 pm
This thing?
Wed Jan 04, 2017 2:38 pm
