It is currently Wed Apr 08, 2026 3:24 pm
[ 8 posts ] |
WI WATERFOWL
 Timing Key Install
Looking to install an advanced timing key, when re-torquing the flywheel nut, what is the best way form stopping the shaft from spinning.
I had put a piece of wood between the prop and cavitation plate last time two problems, sheered the key so I must not have it it torqued all the way and i bent my cavitation plate. Next project will be trying to straighten that out.
| Tue Jan 03, 2017 3:58 pm |
nuccifish06
Joined: Tue Sep 16, 2014 6:36 pm Posts: 108 Location: Sunrise, FL
 Re: Timing Key Install
I'm about to get into this with the engine off the frame. I could use some advice on this as well...
_________________ 1438 Jon / 23hp MBLT
| Wed Jan 04, 2017 8:57 am |
MaXXis85
Impact gun!
| Wed Jan 04, 2017 10:07 am |
Will C
| Wed Jan 04, 2017 10:30 am |
nuccifish06
1 1/4" socket correct? (23hp)
| Wed Jan 04, 2017 10:53 am |
WI WATERFOWL
So some debate on the impact gun, but when torquing the nut how do you best stop the output shaft from just spinning?
| Wed Jan 04, 2017 1:39 pm |
Will C
Fly wheel tool. It grabs the teeth to hold it. Its an automotive tool.
| Wed Jan 04, 2017 2:15 pm |
nuccifish06
This thing?
| Wed Jan 04, 2017 2:38 pm |
[ 8 posts ] |
