Briggs Vanguard 35 bearing and bore vs cyl tolerances ?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=69480
Author:  justooln2 [ Tue Jan 10, 2017 6:35 am ]
Post subject:  Briggs Vanguard 35 bearing and bore vs cyl tolerances ?
Briggs and Stratton 613477-0121-E1
I have found all the parts and part sources I will use, with no dimensions.
I am trying to find the actual size and tolerances for the following;
Pistons:
Cylinders:
Rod:
Rod journal to piston pin:
Crank end play:
I am building this back to 80% stock, new cam and valves. Head work and port and polish everything as well as gasket match everything.
Intake Valve Dimensions // Exhaust valve Dimensions
Stem= .234 // Stem= .234
Keeper= .196 Keeper= .198
Seat OD= 1.423 / 1.418 // Seat OD= 1.276 / 1.277
45* seat face .109 / .120 // 45* seat face= .110
Unmachined back angle= .053 / .045 // Unmachined back angle= .050/.049
Seat thickness= .130 / .126 // Seat thickness= .128/.132
Bore #1 180* // #2 180*
TOP 3.367 3.3665 // 3.366 3.3665
MID 3.367 3.368 // 3.367 3.3675
BTM 3.367 3.367 // 3.367 3.366
Piston #1 // #2
TOP 3.360 // 3.360
MID 3.363 // 3.363
BTM 3.363 // 3.363
Thanks for any productive input.
Author:  justooln2 [ Mon Jan 23, 2017 6:07 pm ]
Post subject:  Re: Briggs Vanguard 35 bearing and bore vs cyl tolerances ?
Info for the next guy. Thanks for the help.
Armature Air Gap . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.005 – 0.007 (0.13 – 0.18)
Crankshaft End Play . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.002 – 0.012 (0.05 – 0.30)
Spark Plug Gap . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.020 (0.51)
Valve Clearance – Measured Cold
Intake . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.004 – 0.006 (0.10 – 0.15)
Exhaust . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.004 – 0.006 (0.10 – 0.15)
Dimensional Specifications
NOTE: All dimensions in Inches (Millimeters)
Description Standard Dimension Reject Dimension
Cylinder
Bore . . . . . . . . . . . . . . . 3.366 (85.50) . . . . . . . . . . . . . . . . 3.369 (85.57)
Out-of-round . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.002 (0.05)
Main Bearing. . . . . . . . . . 1.775 (45.09) . . . . . . . . . . . . . . . . 1.777 (45.12)
Cam Bearing . . . . . . . . . . 0.630 – 0.631 (16.00 – 16.03) . . . . . . . . . . . . . . . . 0.633 (16.08)
Cylinder Head
Valve Guide . . . . . . . . . . .. 0.2366 – 0.237 (6.01 – 6.02) . . . . . . . . . . . . . . . . . 0.238 (6.05)
Valve Stem–
Intake . . . . . . . . . . . . . . . 0.234 – 0.235 (5.95 – 5.96) . . . . . . . . . . . . . . . . . . 0.233 (5.92)
Exhaust . . . . . . . . . . . . . . 0.2338 – 0.234 (5.94 – 5.95) . . . . . . . . . . . . . . . . . 0.2327 (5.91)
Crankcase Cover
Main Bearing . . . . . . . . . . .1.3795 – 1.380 (35.04 – 35.05) . . . . . . . . . . . . . . . 1.381 (35.07)
Cam Bearing . . . . . . . . 0.7874 – 0.788 (20.0 – 20.02) . . . . . . . . . . . . . . . . 0.789 (20.04)
Crankshaft
Crankpin . . . . . . . . . . . 1.654 (42.01) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.6525 (41.97)
Magneto Journal . . . . . . . . . . . . . . . . . . . . . . . . . . 1.771 (44.98) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.7695 (44.95)
PTO Journal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.771 (44.98) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.7695 (44.95)
Camshaft
Magneto Journal . . . . . . . . . . . . . . . . . . . . . . . . . . 0.786 (19.96) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.7485 (19.93)
PTO Journal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.786 (19.96) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.7485 (19.93)
Connecting Rod
Crankpin Bearing . . . . . . . . . . . . . . . . . . . . . . . . . . 1.656 (42.06) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.658 (42.11)
Piston Pin Bearing . . . . . . . . . . . . . . . . . . . . . . . . . 0.827 (21.01) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.828 (21.03)
Piston Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8268 (21.00) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8258 (20.98)
Piston Pin Bearing (Piston) . . . . . . . . . . . . . 0.827 (21.01) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.828 (21.03)
Piston Rings
End Gap
Top . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.007 – 0.013 (0.20 – 0.35) . . . . . . . . . . . . . . . . . . 0.030 (0.76)
Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.013 – 0.021 (0.35 – 0.55) . . . . . . . . . . . . . . . . . . 0.030 (0.76)
Oil . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.007 – 0.057 (0.20 – 0.70) . . . . . . . . . . . . . . . . . . 0.040 (1.00)
Side Clearance
Top . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.003 (0.07) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.006 (0.15)
Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.002 (0.05) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.004 (0.10)
Oil . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.0015 (0.04) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.008 (0.20)
185
Torque Values
Description Torque
Air Cleaner Mounting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 190 in. lbs. (21 Nm)
Air Guide Mounting Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Air Block Plate Mounting Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Alternator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 in. lbs. (4 Nm)
Alternator Harness Clamp Screw . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Air Cleaner Base (to carburetor) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65 in. lbs. (7 Nm)
Air Cleaner Support Bracket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65 in. lbs. (7 Nm)
Armature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 in. lbs. (4 Nm)
Back Plate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Blower Housing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Breather . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 in. lbs. (5 Nm)
Carburetor to Manifold . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Carburetor Intake Elbow to Carburetor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Connecting Rod . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 125 in. lbs. (14 Nm)
Crankcase Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 in. lbs. (23 Nm)
Cylinder Head . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 350 in. lbs. (40 Nm)
Cylinder Shield . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Exhaust Manifold . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 in. lbs. (23 Nm)
Flywheel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 ft. lbs. (203 Nm)
Flywheel Fan Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Fuel Pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 in. lbs. (5 Nm)
Governor Control Bracket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 in. lbs. (23 Nm)
Governor Lever Nut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 in. lbs. (8 Nm)
Ignition Armature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 in. lbs. (3 Nm)
Intake Manifold . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 180 in. lbs. (20 Nm)
Oil Drain Plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 180 in. lbs. (20 Nm)
Oil Pickup to Pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Oil Pressure Switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 in. lbs. (9 Nm)
Oil Pump to Crankcase Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Regulator Rectifier . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm)
Rocker Arm Lock Nut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 in. lbs. (8 Nm)
Rocker Arm Stud . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 in. lbs. (11 Nm)
Rotating Screen Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 in. lbs. (11 Nm)
Rotating Screen Studs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 125 in. lbs. (14 Nm)
Spark Plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 180 in. lbs. (20 Nm)
Starter Motor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 in. lbs. (16 Nm)
Valve Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 in. lbs. (8 Nm)
Author:  Will C [ Mon Jan 23, 2017 6:19 pm ]
Good info, thanks for sharing
Author:  Russ [ Mon Jan 23, 2017 6:25 pm ]
Sticky
Thanks to the OP.
Some of the torque specs were already in a sticky, but those tolerances and measurements werent.
