| Flywheel messing with carb http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=69487 |
| Author: | Duck-killa [ Tue Jan 10, 2017 5:41 pm ] |
| Post subject: | Flywheel messing with carb |
So awhile back I changed my stator and after a little while something happend behind the flywheel and cut my wires. Well my engine was running fine before I decided to take the flywheel back off to fix the stator problem, so I did what I had to do and fixed the wires and whatnot, and I put the flywheel on just like before, gapped my coils with a business card and now I wouldn't start back up. Blowing smoke out the carb and jerking the flywheel when it goes to crank. So I thought it was something with the carb and my minkui carb was coming in anyway so I just took it off, and I installed my minkui today and same thing. Jerking the flywheel, blowing smoke out the carb, running very rough and only for about 15 seconds then dying, really confused here |
| Author: | flint87 [ Tue Jan 10, 2017 5:46 pm ] |
| Post subject: | Re: Flywheel messing with carb |
Really confused here too.... Sent from my iPhone using Tapatalk |
| Author: | Duck-killa [ Tue Jan 10, 2017 5:53 pm ] |
Maybe timing is off on the flywheel somehow |
| Author: | Will C [ Tue Jan 10, 2017 8:08 pm ] |
Yes^ |
| Author: | banded-mallard [ Wed Jan 11, 2017 5:21 am ] |
Right, check your keyway. If you have a timing key, may be broken. Your flywheel isn't line up correctly. |
| Author: | brycecheramie [ Wed Jan 11, 2017 5:31 am ] |
| Author: | MaXXis85 [ Wed Jan 11, 2017 7:22 am ] |
Your timing key has probably sheared. |
| Author: | Duck-killa [ Wed Jan 11, 2017 9:13 pm ] |
That's what happen, key sheared. Guess I didn't torque it enough, will torque to Briggs specs. |
| Author: | CypressCritter [ Thu Jan 12, 2017 9:42 am ] |
Time to get an advanced timing key!! JS 300-500 rpms on the top end. |
| Author: | MaXXis85 [ Thu Jan 12, 2017 10:14 am ] |
Its around 150 Foot pounds. I have a cheat sheet I keep in the shop. |
| Author: | Duck-killa [ Thu Jan 12, 2017 11:18 am ] |
I don't need any more rpms on this thing 4700 rpms is plenty enough for me lol |
| Author: | CypressCritter [ Thu Jan 12, 2017 11:21 am ] |
Get a bigger Prop or go up in pitch! |
| Author: | nuccifish06 [ Thu Jan 12, 2017 1:20 pm ] |
| Author: | Duck-killa [ Thu Jan 12, 2017 9:48 pm ] |
Well my GT 2 blade is still in pretty good condition but before next season, I'm gonna pick up the delta mercury 3 blade, might leave it how it is or get an extra cup in it |
