It is currently Mon Apr 06, 2026 10:20 am
Reply to topic  [ 16 posts ]
 4400 Black Death
Post 4400 Black Death
What fuel/water separator do you recommend for this motor? I was thinking a Racor 10 micron filter, but they rate them per GPH (Gallons Per Hour) so do not know which one to buy of if I should even buy the Racor,,, Its what I know, I have it on my off shore boat.
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Wed Jan 18, 2017 2:19 pm
Profile YIM
Post Re: 4400 Black Death
If you use it on your outboard, it should be fine to use on your motor.
Refurbishing a Prodrive
Wed Jan 18, 2017 2:23 pm
yea but my outboard is a 250hp with a completely diff. gas pump system...
Wed Jan 18, 2017 2:35 pm
Profile YIM
http://lmgtfy.com/?q=water+fuel+separator+mudmotortalk
Wed Jan 18, 2017 2:52 pm
I'm using a transom mount Yamaha Water separator, takes a Wix screw on filter. On my BD 45. Been changing filter every spring. Motor has the stock vacuum style fuel pump, pulling thru 16' of 3/8 fuel line. 3/8s into Filter housing 1/4 to inline filter and carb. Havn't had any water issues since installation.
Wed Jan 18, 2017 2:59 pm
Dude you need to run that bassard more if you're worried about H2O....
PRODRIVE 1860 CC
"Let the good times roll"
Wed Jan 18, 2017 7:55 pm
Thu Jan 19, 2017 11:22 am
Thu Jan 19, 2017 11:24 am
on the 4400 Black Death.... what oil filter do I get, and how much oil does it take. I am picking my boat up next week and just want to get the oil and a spare oil filter while I'm at it....
Fri Feb 03, 2017 3:54 pm
Profile YIM
Sat Feb 04, 2017 6:48 am
Profile YIM
Do you know how google works?
Sat Feb 04, 2017 11:42 am
What's that? ..... couldn't find anything, was hoping using this forum for information and to give advice would be the logical answer....
Sat Feb 04, 2017 1:38 pm
Profile YIM
See my post on water separator, usually on a short run you can get by with 1/4" I.D. for longer runs larger I.D. hose might be needed. Makes it easier on pulse diaphragm type fuel pumps. If electric pump is used in line it doesn't make much difference. I'm using 1/4" from separator to carb.
Sat Feb 04, 2017 4:53 pm
Using the Google search and mmt or mudmotor talk in the search brings you to the topics already covered on this site concerning your search term. Use it. Plenty of people that don't frequent here anymore have posted lots of good information to answer about 98% of the questions that have been asked the last 6-8 months here. You're missing alot of the detailed info about exactly what your asking because of your refusal to not use Google to search this forum.
Sat Feb 04, 2017 5:08 pm
Sun Feb 05, 2017 5:49 am
Profile YIM
Your welcome, any of the BPS-MB pro staff members will be glad to help you with any of your questions on your new rig. That's what we're here for.
Sun Feb 05, 2017 9:31 am
