leachclan
Backfire
35 gatortail with mukuni backfired at full throttle and died. Have cleaned carb changed fuel filter replaced fuel line and plugs. Will not start and continues to backfire while trying to start any suggestions.
Sat Jan 21, 2017 5:46 pm |
Will C
Re: Backfire
Pull valve covers and inspect pushrods n rockers. Could have also popped intake gaskets.. still got good fire?
Sat Jan 21, 2017 6:28 pm |
Bug
Joined: Sat Oct 29, 2011 10:28 am Posts: 1068 Location: Tallahassee, Fl
Re: Backfire
Or sheared flywheel timing key
_________________ PRODRIVE 1860 CC "Let the good times roll" Luck??? The bassards don't stand a chance!
Sun Jan 22, 2017 9:18 am |
brycecheramie
Re: Backfire
Sun Jan 22, 2017 10:36 am |
BlackTJ35
Re: Backfire
Could be something grounding coils. Mine did the same thing when the oil sensor went out
Sun Jan 22, 2017 1:02 pm |
Duck-killa
Joined: Sun Apr 08, 2012 10:48 pm Posts: 154 Location: Cut Off, LA
Re: Backfire
Yea that's exactly what happens to mine, a key is cheap and pretty easy to fix unless it's really stuck like mine was, but make sure you put a torque wrench on it and I'm pretty sure Briggs says it's 150lbs, I learned the hard way of not doing this
_________________ Delta lvl 3 GTR with MAC 16x54 Gator hull
Sun Jan 22, 2017 1:05 pm |
leachclan
Re: Backfire
Thank y'all for the help will post what problem is when I get to work on it Tuesday. I felt it was a valve. Brother hit a stup and it happened.
Sun Jan 22, 2017 6:41 pm |
Will C
Re: Backfire
If it happened when u hit a stump,,, then x3 on the timing key
Sun Jan 22, 2017 8:57 pm |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
Re: Backfire
Valve train issues or sheared key in the crank. Both easy repairs but one takes a bit more time. These would be the first two things i'd check.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
Mon Jan 23, 2017 5:33 am |
leachclan
Re: Backfire
Thanks if it is the timing key where can I get a new one
Mon Jan 23, 2017 6:30 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
Re: Backfire
A Briggs and Stratton lawnmower repair shop. Seriously.
A mud motor dealer that sells units with Briggs engines and does repair work should have one as well.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
Mon Jan 23, 2017 6:48 am |
leachclan
Re: Backfire
Thanks dickhead. We have mud motor dealers on every street corner in Carthage who knew.
Mon Jan 23, 2017 5:01 pm |
cb5331
Re: Backfire
WTF?
Mon Jan 23, 2017 5:26 pm |
Russ
Re: Backfire
He wasn't being a dick, fucktard. You don't have to have one nearby to be able to find a phone number for one and call them. You asked where to get a timing key, someone tried to help. Amazon has them too. But I suppose you already knew that and just asked because you wanted to create an Internet test for the people of mmt. You can make one out of aluminum foil if you get creative and you're in such a hurry that ordering one or calling a dealer in another town, city, or state takes too long.
Unappreciative jackass of the week.....
Mon Jan 23, 2017 5:48 pm |
Will C
Re: Backfire
the "philosopher"
Mon Jan 23, 2017 6:23 pm |
flint87
Re: Backfire
Mon Jan 23, 2017 7:49 pm |
cb5331
Re: Backfire
Think she'd be the third or fourth. We had dipstalker and chicklet.
Mon Jan 23, 2017 8:04 pm |
Russ
Re: Backfire
The first 3, as I remember, fit right in.
This is more of a "I'm better than you, and I misread what I was reading and took offense because I have an inferiority complex and thought I was being called stupid" because someone knew something he didn't.
Mon Jan 23, 2017 8:15 pm |
brycecheramie
Re: Backfire
This went south in a hurry! lol I would say you gotta have thick skin to be around here, but this guy is here and his skins as thin as a piece a paper!
Tue Jan 24, 2017 4:09 am |
leachclan
Re: Backfire
First off my sincere apologies I read that wrong was on my fourth night in row of work. Thanks to everyone of you for the help. It was a push rod that had slipped off the rocker. Put back on checked clearances clean rocker bolt a put lock tite and torqued back down. Can't thank all of y'all enough for the help. Once again please accept my apology for the dick head commit appears the only dick head was me.
Tue Jan 24, 2017 1:15 pm |
Russ
Re: Backfire
Dude, you're the first to ever own up to something like that here. Welcome to the crew, glad you got it fixed.
For the edumication of others, was that on cylinder 1 or 2 (starter side or oil filter side)? Typically if it's the oil filter side, the engine will still crank and run on cylinder 1, but wont on cylinder 2. I only ask because when we help someone troubleshoot, we go off of experiences we or those we know have had, and I'm just curious which cylinder it was.
Tue Jan 24, 2017 1:38 pm |
leachclan
Re: Backfire
It was on the oil filter side exhaust valve. FYI don't ever tell my wife I said I was wrong. Also this boat was bought used two weeks ago so probably not adjusted by previous owner.
Tue Jan 24, 2017 9:47 pm |
chicklet
Re: Backfire
Sat Jan 27, 2018 1:07 pm |
cb5331
Re: Backfire
Sat Jan 27, 2018 3:53 pm |
