It is currently Sun Apr 12, 2026 12:09 pm
[ 5 posts ] |
Briggs Vanguard 35 bearing and bore vs cyl tolerances ?
justooln2
Joined: Fri Dec 16, 2016 7:41 am Posts: 7 Location: Central Il 61526
Briggs and Stratton 613477-0121-E1
I have found all the parts and part sources I will use, with no dimensions.
I am trying to find the actual size and tolerances for the following; Pistons: Cylinders: Rod: Rod journal to piston pin: Crank end play:
I am building this back to 80% stock, new cam and valves. Head work and port and polish everything as well as gasket match everything. Intake Valve Dimensions // Exhaust valve Dimensions Stem= .234 // Stem= .234 Keeper= .196 Keeper= .198 Seat OD= 1.423 / 1.418 // Seat OD= 1.276 / 1.277 45* seat face .109 / .120 // 45* seat face= .110 Unmachined back angle= .053 / .045 // Unmachined back angle= .050/.049 Seat thickness= .130 / .126 // Seat thickness= .128/.132
Bore #1 180* // #2 180* TOP 3.367 3.3665 // 3.366 3.3665 MID 3.367 3.368 // 3.367 3.3675 BTM 3.367 3.367 // 3.367 3.366
Piston #1 // #2 TOP 3.360 // 3.360 MID 3.363 // 3.363 BTM 3.363 // 3.363
Thanks for any productive input.
| Tue Jan 10, 2017 6:35 am |
justooln2
 Re: Briggs Vanguard 35 bearing and bore vs cyl tolerances ?
Info for the next guy. Thanks for the help.
Armature Air Gap . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.005 – 0.007 (0.13 – 0.18) Crankshaft End Play . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.002 – 0.012 (0.05 – 0.30) Spark Plug Gap . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.020 (0.51) Valve Clearance – Measured Cold Intake . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.004 – 0.006 (0.10 – 0.15) Exhaust . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.004 – 0.006 (0.10 – 0.15) Dimensional Specifications NOTE: All dimensions in Inches (Millimeters) Description Standard Dimension Reject Dimension Cylinder Bore . . . . . . . . . . . . . . . 3.366 (85.50) . . . . . . . . . . . . . . . . 3.369 (85.57) Out-of-round . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.002 (0.05) Main Bearing. . . . . . . . . . 1.775 (45.09) . . . . . . . . . . . . . . . . 1.777 (45.12) Cam Bearing . . . . . . . . . . 0.630 – 0.631 (16.00 – 16.03) . . . . . . . . . . . . . . . . 0.633 (16.08) Cylinder Head Valve Guide . . . . . . . . . . .. 0.2366 – 0.237 (6.01 – 6.02) . . . . . . . . . . . . . . . . . 0.238 (6.05) Valve Stem– Intake . . . . . . . . . . . . . . . 0.234 – 0.235 (5.95 – 5.96) . . . . . . . . . . . . . . . . . . 0.233 (5.92) Exhaust . . . . . . . . . . . . . . 0.2338 – 0.234 (5.94 – 5.95) . . . . . . . . . . . . . . . . . 0.2327 (5.91) Crankcase Cover Main Bearing . . . . . . . . . . .1.3795 – 1.380 (35.04 – 35.05) . . . . . . . . . . . . . . . 1.381 (35.07) Cam Bearing . . . . . . . . 0.7874 – 0.788 (20.0 – 20.02) . . . . . . . . . . . . . . . . 0.789 (20.04) Crankshaft Crankpin . . . . . . . . . . . 1.654 (42.01) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.6525 (41.97) Magneto Journal . . . . . . . . . . . . . . . . . . . . . . . . . . 1.771 (44.98) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.7695 (44.95) PTO Journal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.771 (44.98) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.7695 (44.95) Camshaft Magneto Journal . . . . . . . . . . . . . . . . . . . . . . . . . . 0.786 (19.96) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.7485 (19.93) PTO Journal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.786 (19.96) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.7485 (19.93) Connecting Rod Crankpin Bearing . . . . . . . . . . . . . . . . . . . . . . . . . . 1.656 (42.06) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.658 (42.11) Piston Pin Bearing . . . . . . . . . . . . . . . . . . . . . . . . . 0.827 (21.01) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.828 (21.03) Piston Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8268 (21.00) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8258 (20.98) Piston Pin Bearing (Piston) . . . . . . . . . . . . . 0.827 (21.01) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.828 (21.03) Piston Rings End Gap Top . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.007 – 0.013 (0.20 – 0.35) . . . . . . . . . . . . . . . . . . 0.030 (0.76) Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.013 – 0.021 (0.35 – 0.55) . . . . . . . . . . . . . . . . . . 0.030 (0.76) Oil . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.007 – 0.057 (0.20 – 0.70) . . . . . . . . . . . . . . . . . . 0.040 (1.00) Side Clearance Top . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.003 (0.07) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.006 (0.15) Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.002 (0.05) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.004 (0.10) Oil . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.0015 (0.04) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.008 (0.20) 185 Torque Values Description Torque Air Cleaner Mounting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 190 in. lbs. (21 Nm) Air Guide Mounting Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Air Block Plate Mounting Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Alternator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 in. lbs. (4 Nm) Alternator Harness Clamp Screw . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Air Cleaner Base (to carburetor) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65 in. lbs. (7 Nm) Air Cleaner Support Bracket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65 in. lbs. (7 Nm) Armature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 in. lbs. (4 Nm) Back Plate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Blower Housing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Breather . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 in. lbs. (5 Nm) Carburetor to Manifold . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Carburetor Intake Elbow to Carburetor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Connecting Rod . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 125 in. lbs. (14 Nm) Crankcase Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 in. lbs. (23 Nm) Cylinder Head . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 350 in. lbs. (40 Nm) Cylinder Shield . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Exhaust Manifold . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 in. lbs. (23 Nm) Flywheel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 ft. lbs. (203 Nm) Flywheel Fan Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Fuel Pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 in. lbs. (5 Nm) Governor Control Bracket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 in. lbs. (23 Nm) Governor Lever Nut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 in. lbs. (8 Nm) Ignition Armature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 in. lbs. (3 Nm) Intake Manifold . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 180 in. lbs. (20 Nm) Oil Drain Plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 180 in. lbs. (20 Nm) Oil Pickup to Pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Oil Pressure Switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 in. lbs. (9 Nm) Oil Pump to Crankcase Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Regulator Rectifier . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 in. lbs. (10 Nm) Rocker Arm Lock Nut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 in. lbs. (8 Nm) Rocker Arm Stud . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 in. lbs. (11 Nm) Rotating Screen Screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 in. lbs. (11 Nm) Rotating Screen Studs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 125 in. lbs. (14 Nm) Spark Plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 180 in. lbs. (20 Nm) Starter Motor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 in. lbs. (16 Nm) Valve Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 in. lbs. (8 Nm)
| Mon Jan 23, 2017 6:07 pm |
Will C
Good info, thanks for sharing
| Mon Jan 23, 2017 6:19 pm |
Russ
Sticky
Thanks to the OP.
| Mon Jan 23, 2017 6:25 pm |
Russ
Some of the torque specs were already in a sticky, but those tolerances and measurements werent.
[ 5 posts ] |
