| Mikuni Tuning - 36 PD, IM Heads, SW Exhaust, 1860 Phowler http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=69610 |
| Author: | JCR2013 [ Mon Jan 23, 2017 12:40 pm ] |
| Post subject: | Mikuni Tuning - 36 PD, IM Heads, SW Exhaust, 1860 Phowler |
Having a hard time getting my Mikuni dialed in. I have a "pop" that occurs when running just above idle. Also, no matter what size pilot jet i run, my air mixture screw setting will not change. Just 3/4 turn out from bottom. Anyone out there with a similar set-up have this issue? HSR 42 Mikuni 30 Pilot Jet 160 Main Jet 97 Jet Needle on 3rd clip position |
| Author: | cb5331 [ Mon Jan 23, 2017 2:10 pm ] |
| Post subject: | Re: Mikuni Tuning - 36 PD, IM Heads, SW Exhaust, 1860 Phowle |
Pilot sounds too big, main sounds too small. Don't remember the needle sizes, but what comes in them works for most, middle clip, one up or one down.. 22.5 or 25 pilot works for us 165 or 167.5 i'd guess on the main |
| Author: | JCR2013 [ Mon Jan 23, 2017 2:19 pm ] |
OK... I tried the 27.5 and then 30 pilot jet per the following from the tuning manual... 1. If the best idle is achieved with the air screw less than one turn out, the pilot jet is too small and should be exchanged for a larger one. Since that didn't help I guess I will put the 25 back in and try other options. |
| Author: | Will C [ Mon Jan 23, 2017 2:34 pm ] |
Have you tried tightening the gap on acc pump? Also valves adjusted and good leakdown |
| Author: | JCR2013 [ Mon Jan 23, 2017 3:31 pm ] |
I have the acc pump gap set to a little bit smaller than a credit Card. Valve lash is good. I have not checked leak down. But my top end and idle and everything else seems good. |
| Author: | Will C [ Mon Jan 23, 2017 6:25 pm ] |
Does is feel like a "lean cough" u got a video? |
| Author: | Russ [ Mon Jan 23, 2017 6:35 pm ] |
Raise the needle by dropping the clip 1 position. Should help that pop if it's lean. |
| Author: | JCR2013 [ Tue Jan 24, 2017 8:18 am ] |
| Author: | Will C [ Tue Jan 24, 2017 8:47 am ] |
As russ said,,, raise the needle and see if the extra fuel helps |
| Author: | JCR2013 [ Tue Jan 24, 2017 9:17 am ] |
https://www.icloud.com/attachment/?u=ht ... z=66005228 |
| Author: | cb5331 [ Tue Jan 24, 2017 9:20 am ] |
I would think it's loading up because of that big ass pilot jet, not leaning out, but I'm no carb guru... |
| Author: | JCR2013 [ Tue Jan 24, 2017 9:26 am ] |
| Author: | cb5331 [ Tue Jan 24, 2017 9:28 am ] |
Is this a brand new carb? New jets as well? |
| Author: | Will C [ Tue Jan 24, 2017 9:49 am ] |
Watched vid. That sounds like a lean cough. swap to a 170 main and raise needle. Once your dialed in better u can come down a bit on main |
| Author: | Will C [ Tue Jan 24, 2017 9:50 am ] |
Also make sure you have no vacuum leaks |
| Author: | cb5331 [ Tue Jan 24, 2017 9:52 am ] |
Down from a 160? |
| Author: | Will C [ Tue Jan 24, 2017 10:06 am ] |
Down from 170 |
| Author: | cb5331 [ Tue Jan 24, 2017 10:09 am ] |
My bad, I missed that in your post. I'm out... I hate carbs and jetting. |
| Author: | JCR2013 [ Tue Jan 24, 2017 10:17 am ] |
| Author: | Will C [ Tue Jan 24, 2017 10:34 am ] |
Your crankcase vent should be fine like you have it. Rubber Boot to intake adapter or intake to heads. The bottom line is you need a bit more fuel in that spot |
| Author: | brickgw [ Tue Jan 24, 2017 2:19 pm ] |
Where are you located? |
| Author: | JCR2013 [ Tue Jan 24, 2017 2:22 pm ] |
| Author: | brickgw [ Tue Jan 24, 2017 2:27 pm ] |
| Author: | JCR2013 [ Tue Jan 24, 2017 2:34 pm ] |
| Author: | brickgw [ Tue Jan 24, 2017 2:42 pm ] |
