It is currently Sun Apr 05, 2026 4:55 am
Reply to topic  [ 13 posts ]
 Anybody with a 23 Vanguard
Post Anybody with a 23 Vanguard
How much difference did a Mikuni carb and/or Mac exhaust make?
Sat Jul 16, 2016 2:35 pm
Post Re: Anybody with a 23 Vanguard
fuel consumption goes up its easier to dial in a/f your really not going to see a big bump in performance maybe a mph or 2. not really worth adding the carb unless you do heads or cam.
1744 floating a 23 MBHD Stage 2
Mon Jul 18, 2016 8:53 am
what does a/f mean? And puddler, are you just addressing the carb in your response, or do you also mean there's no jump in speed when adding a mac exhaust? have you tried the Mac? Thanks man.
Fri Jan 20, 2017 8:21 pm
Puddler, are you addressing just the carb when you say "only and increase in a mile or 2mph'? or also the Mac exhaust? Have you tried a Mac? I have a Copperhead 18 and am trying to get more hp from it, and I was told it would vastly improve the holeshot and midrange power, but not sure how it would affect the top end other than it would add 100rpm to the stock Copperhead 18. Thanks.
Fri Jan 20, 2017 8:27 pm
He's talking about adding a carb and an exhaust will only give you a mile an hour or two, and without heads or cam, you really won't see big performance gains, I have a mac on my 35 hp and there's really no speed difference, you get little performance gains out of just an exhaust, just helps your motor breath better if you have mods , and it's really loud. Too loud actually
Delta lvl 3 GTR with MAC
16x54 Gator hull
Thu Jan 26, 2017 7:18 pm
Stock 23.5 added bps exhaust with stock carb. 24mph
with bps intake kit 34mm mikuni 24.5mph
Heads decked .025 stainless valves, shimmed springs , port work and billet cam with mikuni carb. 26
All of the above with lectron carb 28.2 at 4380 rpm
So like puddler said about 1-2 mph
Save the money for a lectron and don't buy a mikuni IMO
Fri Jan 27, 2017 4:44 pm
Fri Jan 27, 2017 5:35 pm
Fri Jan 27, 2017 6:24 pm
That carb wasn't tuned correctly. Nice to see the gains you got going to the lectron, but jetting and tuning a carb correctly would've proved better results with that mikuni than you were seeing. That's not your fault, as you were sold what was supposed to be right for your engine.
Fri Jan 27, 2017 7:49 pm
Fri Jan 27, 2017 8:57 pm
Are they still sending out the round slide?
Fri Jan 27, 2017 9:49 pm
Sat Jan 28, 2017 8:06 am
Man I'm glad I just got a piece of shit in tunable carb. Great.
Sat Jan 28, 2017 9:28 am
