MB 45 Mag strange clutch issue
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=69685
Author:  Slabguy [ Mon Jan 30, 2017 10:36 am ]
Post subject:  MB 45 Mag strange clutch issue
I have a 2010 mud buddy 45 mag with about 180 hours. I was on the river yesterday and ran for about 30 minutes to the duck hole no problems. Finished hunting and start to head back to the ramp. About 5 minutes in to the ride the clutch disengages itself. This happened multiple times at WOT. I try putting along at 2,000 rpm and the clutch will stay engaged for anywhere from 5-10 minutes then will disengage. Try WOT a couple more times and clutch disengages after about 10 seconds. I limp back to the ramp at 2,000 rpm with the clutch disengaging intermittently. While on the water I opened up the football to check connection at the clutch switch and everything seemed fine. Could the switch be going bad or does this sound like a bad clutch? Any other suggestions? Thanks.
Author:  Will C [ Mon Jan 30, 2017 10:49 am ]
Post subject:  Re: MB 45 Mag strange clutch issue
Sounds like wiring. Inspect wiring to clutch, might even pull clutch cover to inspect the wiring where it goes through the frame.
Author:  CypressCritter [ Mon Jan 30, 2017 11:21 am ]
Check switch, had 2 go bad on a GTR, if that switch ain't 30 amp rated, replace it with one that is. An electrical coil engages the clutch, a coil is nothing more than a piece of wire, in other words almost like a short. Yes it will heat up any bad or questionable connections.
Author:  JD145 [ Mon Jan 30, 2017 1:02 pm ]
When I had this issue it was the switch going bad
Author:  dwbiggs [ Mon Jan 30, 2017 3:54 pm ]
Check the clutch mounting bolt.
Author:  cb5331 [ Mon Jan 30, 2017 8:35 pm ]
Author:  Smoke [ Tue Jan 31, 2017 10:58 am ]
Sounds like a short in the wire harness some where. Since you checked the football area, pull cover and check inside the belt box and see if a wire hasn't been rubbed bare. Also check closer in the football. Those wires are stuffed in there pretty tight.
Author:  Slabguy [ Fri Feb 03, 2017 2:16 pm ]
Talked to Boat Dr. and got a new switch and relay headed my way. I'll also pull the cover and check the wiring to the clutch. Hopefully one of these things fixes the issue. Thanks.
