| Friends motor.... what should I check first? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=69721 |
| Author: | ibfishinb [ Sat Feb 04, 2017 5:59 pm ] |
| Post subject: | Friends motor.... what should I check first? |
It died on him yesterday while running. He thought it locked up. There was oil in it bit it was a little low. He added oil and tried turning it over. It turned over super slow and would not fire. He waited about 30 mins and it fired right up and he headed in. He went out this evening for youth day. When be stopped to put decoys out the motor had been running fine. Went to start it and it was turning over super slow (kinda like a low battery). Sat there for about 10 mins then it fired right up. After the youth hunt he fired up gathered everything and went to the ramp. Once on the trailer he went to fire it up gain. Once again turned over super slow. He kept turning it and it fired. A plume of black smoke poured out of the exhaust for several seconds. It cleared up and I ran fine. Valves? Carburetor? Timing? Where do you think I should start? Sent from my SM-G920V using Tapatalk |
| Author: | Bug [ Sat Feb 04, 2017 6:31 pm ] |
| Post subject: | Re: Friends motor.... what should I check first? |
Electrical connections, battery connections first, then starter then fuel cutoff solenoid plug and the key switch lastly assuming its a stocker carbed engine. Prolly some corrosion on battery or starter leads. Clean ground and tighten... |
| Author: | ibfishinb [ Sat Feb 04, 2017 6:34 pm ] |
Will do. He already checked all the electrical connections and tested the battery voltage today before going out though. It is a bone stock motor. A 2009 mudbuddy. Sent from my SM-G920V using Tapatalk |
| Author: | cb5331 [ Sun Feb 05, 2017 12:21 pm ] |
You have to load test the battery. Just checking the resting voltage won't tell the whole story. |
| Author: | ibfishinb [ Sun Feb 05, 2017 12:38 pm ] |
Gotcha... going to check it under load. Sent from my SM-G920V using Tapatalk |
| Author: | Old School [ Sun Feb 05, 2017 12:49 pm ] |
Go buy a battery load tester. They are cheap and you will be surprised how often you will use it or somebody you know will need it. |
| Author: | Bug [ Mon Feb 06, 2017 6:25 am ] |
^^^^Amen to THAT! |
| Author: | ibfishinb [ Mon Feb 06, 2017 6:33 am ] |
Another friend load tested the battery. It is fine. When it shuts off and has a hard time turning over. At this point with the clutch engaged you cannot spin the prop by hand. Give it 30 minutes then you can and it will fire up resulting in a plume of black smoke briefly. Then it purrs like a kitten.... until it gets hot and you turn it off. Sent from my SM-G920V using Tapatalk |
| Author: | MaXXis85 [ Mon Feb 06, 2017 7:35 am ] |
I've run across this issue.. Customer insisted on me buying him a new starter.... I said they RARELY go out. I will find the issue. It was the yellow Start wire from the sealed connector to the starter solenoid terminal. It had a nick/bend that was overlooked. Once hot motor wouldn't turn over at all. Once cooled a little it would slowly turn over and fire... CHECK wiring. Needless to say he was happy with a lesser bill and a functioning motor again. |
| Author: | Russ [ Mon Feb 06, 2017 9:40 am ] |
Yep. Starters RARELY go out. I must've pissed off "Denso, the starter god" or "Bart, his sidekick".... |
| Author: | ibfishinb [ Mon Feb 06, 2017 3:56 pm ] |
The part that gets me is the inability to grab the prop by hand and get it to budge when the motor is hot. Then when it cools off it will turn by hand.. Sent from my SM-G920V using Tapatalk |
| Author: | Pigglet [ Mon Feb 06, 2017 7:31 pm ] |
Sounds like it's almost hydrolocking with gas goin on top of the piston. Does the oil smell like gas? May be a needle/seat issue... Sent from my iPhone using Tapatalk |
| Author: | spoonieslayer6 [ Fri Feb 10, 2017 10:30 am ] |
I ran into the same problem....did you ever find out the problem?? I know it's only been a couple days. Sent from my iPhone using Tapatalk |
| Author: | ibfishinb [ Fri Feb 10, 2017 6:44 pm ] |
No... have been to busy to get with him to work on it Sent from my SM-G920V using Tapatalk |
| Author: | Joe Guide [ Sat Feb 11, 2017 5:41 am ] |
Agree with concensius...electrical connections, then battery. Also look at your main wiring harness at those connectiors, then the switch and it's connectors. |
| Author: | Old School [ Sat Feb 11, 2017 8:45 am ] |
Check all grounds. 12v systems are very ground sensitive, even though they may look good, sometimes they need to be cleaned. A good volt meter will help. |
