It is currently Tue Mar 31, 2026 1:56 pm
Reply to topic  [ 5 posts ]
 New briggs EFI and dead battery problem
Post New briggs EFI and dead battery problem
I remember reading from someone on here that Briggs was going to come up with a fix for the new motors that kept the ECU from cooking itself in the event you lost battery power, did this ever happen?
I'm curious because I run my bow fishing lights off my 2 onboard batteries and am super paranoid about running one too low while idling around. Hasn't been a problem yet but it would be nice to know I'm in the clear if I accidentally ran one battery out while idling around bow fishing.
1854 CC backyard build with GTR 37 EFI
Build thread here.. viewtopic.php?f=4&t=66815
Mon Feb 13, 2017 10:53 am
Post Re: New briggs EFI and dead battery problem
Losing power isnt a big deal, But the intermittent on/off and voltage spikes form loose connections is the main concern.
Also your engine charges up to 20 amps at idle.
Mon Feb 13, 2017 11:32 am
I gotcha, well it may just be keeping up with it then. I thought though if you tried to crank with a dead or low battery you were at risk of killing the ECU.
Mon Feb 13, 2017 1:26 pm
*nock on wood* i have one of the early model EFI motors and ive ran my battery dead twice and lost a connection twice while running and nothing happened to the ECU...
Tue Feb 14, 2017 7:14 am
I have a dual battery switch too that you can select battery 1 or 2 or both, I never change it while running but I think it's designed to be changed on the fly. I would assume that would be ill advised...
Tue Feb 14, 2017 9:52 am
