It is currently Thu Apr 02, 2026 3:48 am
Reply to topic  [ 10 posts ]
 Vanguard 35-36-37 stock cam specs
Post Vanguard 35-36-37 stock cam specs
This was checked in a block for accuracy.
Vanguard 35 camshaft
Intake
Open .050" 15* atdc
Close .050" 39* abdc
Icl 117*
Lift .276"
204* duration at .050"
Exhaust
Open .050" 26* bbdc
Close .050" 8* BTDC
Ecl 107*
Lift .260"
198* duration at .050"
Lsa 112*
Tue Feb 21, 2017 7:25 am
Post Re: Vanguard 35-36-37 stock cam specs
so briggs runs that little cam 5* retarded. I Learned somthin new today :D
Tue Feb 21, 2017 8:23 am
Yes, briggs is retarded.
Tue Feb 21, 2017 8:26 am
I knew that was coming, and from you :D
Tue Feb 21, 2017 8:28 am
Those center lines, low lift, low duration, and almost no overlap... Its amazing how well they run stock considering. No wander when you add a cam they make a HUGE jump in power all across the board.
Tue Feb 21, 2017 8:31 am
Tue Feb 21, 2017 8:32 am
Have you checked more than one cam? Seems like I remember Cody saying he'd seen the centerlines off by as much as 5* between two.
Tue Feb 21, 2017 8:33 am
This is the only one I checked. The others have the typical lobe issues This is from a 400 hour PD with perfect spinning tappets and no scarring or worn lobes on the cam.
Tue Feb 21, 2017 8:48 am
Cool! Good info!
Tue Feb 21, 2017 8:55 am
Tue Feb 21, 2017 10:49 am
