It is currently Wed Apr 01, 2026 1:19 pm
[ 4 posts ] |
factory fuel pump question 23hp van
nuccifish06
Joined: Tue Sep 16, 2014 6:36 pm Posts: 108 Location: Sunrise, FL
I've added a low pressure fuel pump to my line because the tank is in the front of the boat. Can I bypass or remove the factory diaphram pump now? I'm sure someone has tried this.
_________________ 1438 Jon / 23hp MBLT
| Thu Mar 02, 2017 11:44 am |
Will C
 Re: factory fuel pump question 23hp van
Sure you can bypass it, but if it's working.....
| Thu Mar 02, 2017 11:56 am |
nuccifish06
fuel drips out of a tiny hole on it constantly so Im not sure if its even working right anyways.
| Thu Mar 02, 2017 12:00 pm |
MaXXis85
One the line is primed and you have no air leaks a diaphragm pump works fine. E pumps are more of a pain, because most installs are sloppy and lead to future issues.
| Thu Mar 02, 2017 1:54 pm |
[ 4 posts ] |
