MALLARDSX2
Joined: Wed Jan 28, 2009 6:34 pm Posts: 978 Location: GA
 CMC Finally Crapped out - Replacement
viewtopic.php?f=3&t=62111&p=841401&hilit=Wiring+a+mercury+trim#p841401I have purchased a mercury style trim unit for my 08 and 09 GTR's. I have my relays from the CMC. I might send those back to someone to have them rebuilt and sell them. I really hate those older trim units. Nothing but problems out of both of mine. Damn things leak all over. Anyhow, I am in need of a little direction on how to wire this new trim up. From what I ready I need to use the old relays. Is that correct? Pretty much follow the post above? Any help would be appreciated. Does anyone know who repairs/rebuilds the CMC type trims? I have two with less than 150 hours on the motors.
| Wed Mar 01, 2017 7:00 am |
MaXXis85
 Re: CMC Finally Crapped out - Replacement
If you keep the same wiring you can use it as is. But GT used a shallco rocker switch that eliminates the relays to simplify the wiring. GT uses a Parker trim now.
| Wed Mar 01, 2017 7:51 am |
MaXXis85
Also whats the plans for the CMC?
| Wed Mar 01, 2017 8:10 am |
MALLARDSX2
Im going to sell them as is or fix them and keep them as spares.
Any ideas where I can get two of these shallco rocker switches?
| Wed Mar 01, 2017 8:24 am |
MALLARDSX2
| Wed Mar 01, 2017 8:53 am |
MaXXis85
| Wed Mar 01, 2017 8:54 am |
MaXXis85
| Wed Mar 01, 2017 8:57 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
After working on outboards for a little bit, got a question. Never had to work on my trim for my mud motor, I know it is a 2 wire motor requiring polarity switching relays. But some are 3 wire and a good heavy duty or one capable of higher than 20 amps[spdt momentary on(mon)-off-on(mon)] will work.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Wed Mar 01, 2017 9:14 am |
cb5331
Use a solenoid, them high dollar switches suck ass.
| Wed Mar 01, 2017 9:32 am |
MALLARDSX2
Mine are two wire. They are the ones that Gator-tail used to have on their website for sale I believe.
| Wed Mar 01, 2017 9:40 am |
CypressCritter
A winch polarity switching relay is not cheap but probably a lot better than relays. a part #24450 is one I have used on ATV winch with good results. $20-$100 depending on where you order it from. https://www.dbelectrical.com/products
| Wed Mar 01, 2017 10:00 am |
cb5331
I know oreilly carries a 120 amp one that wasn't terribly expensive. Blu bought one for his motor before the setx ride. Then you can use the inexpensive toggle switch, and you can replace just the rubber boot by itself if you wear it out.
| Wed Mar 01, 2017 10:03 am |
cb5331
| Wed Mar 01, 2017 10:08 am |
MALLARDSX2
| Thu Feb 01, 2018 7:57 am |
MALLARDSX2
Pictures of my wiring and my temporary exhaust I fabbed up I keep in the boat for when something bad happens to my good one.
| Thu Feb 01, 2018 8:06 am |
MALLARDSX2
It wont let me post the pictures of the wiring?
| Thu Feb 01, 2018 8:09 am |
MALLARDSX2
Wiring
| Thu Feb 01, 2018 8:10 am |
MALLARDSX2
Wiring 2
