It is currently Sun Mar 29, 2026 5:28 pm
Reply to topic  [ 15 posts ]
 Hello, quick question about oil additives
Post Hello, quick question about oil additives
i tried to search for this answer before i posted this but didn't come up with much. so forgive this simple question but
anyone use lucas oil additive or any other kind of additives in there motors ? i have a 2005 PRO DRIVE 27 hp Kohler and about to change the oil. just thought i could get a little input from you gents. thank you
God Bless
Fri Mar 03, 2017 1:52 pm
Post Re: Hello, quick question about oil additives
I asked the same question on here about a year or 2 ago, and the general consensus was not many people if any did because it simply wasn't necessary. We do however, use it in our camps diesel generator and haven't seen any negative results from it, I'm the type that figured any little extra thing I can do to help is worth it!
Fri Mar 03, 2017 2:02 pm
I use primrose 480-M in all my motors, some do some don't it's your preference.
Fri Mar 03, 2017 7:48 pm
A good synthetic oil should be plenty good. Shell Rotella T6 5w-40 ought to cover all bases. Makes for easier starting on cool mornings too. I've been running it in all my air cooled engines for years.
GoDevil 18X44
GoDevil 35 SD
Fri Mar 03, 2017 7:57 pm
10-4 gentleman ! thank you for your responses i appreciate yalls time and have a great weekend..... God Bless
Sat Mar 04, 2017 4:00 am
Don't make it weird.
Sat Mar 04, 2017 9:02 am
Sat Mar 04, 2017 10:03 am
Don't mind him. He, I, bryce and a couple others are just the resident assholes. We have a couple resident mongoloids, but they aren't as frequent as they used to be.
Sat Mar 04, 2017 11:24 am
Sat Mar 04, 2017 11:37 am
Sat Mar 04, 2017 11:44 am
I run some lucas in mine. sometimes I put stp in it too. I have a bad knock and it helps me not hear it so bad. stops up some of the oil leaks too. hit 4000 hours on the motor today chewing up floton/lilies.
if it makes u feel good, run some.
Sat Mar 04, 2017 6:37 pm
Sat Mar 04, 2017 7:25 pm
I run amsoil 3000 in mine
Sat Mar 04, 2017 8:06 pm
Sun Mar 05, 2017 10:31 am
