It is currently Fri Apr 03, 2026 10:43 am
Reply to topic  [ 9 posts ]
 Solenoid Drawing Battery Down
Post Solenoid Drawing Battery Down
So, if anybody's been keeping up, I installed a reversing solenoid and hooked up a toggle switch to replace the junk trim/reverse switch on my console. For some reason or another, this set up seems to be drawing my battery down. What do I have hooked up wrong?
The hydraulic pump works fine throwing the motor into reverse/forward. I did notice when I hooked a new battery back up, the regressing solenoid does make a click sound. What's going on with this thing?
Thanks.
Sat Mar 11, 2017 1:23 pm
Post Re: Solenoid Drawing Battery Down
How it's wired, now.
Sat Mar 11, 2017 1:47 pm
That don't make sense? What type did you buy?
Sat Mar 11, 2017 10:47 pm
Take your power away from your toggle and see if your solenoid stops clicking.
Sun Mar 12, 2017 9:58 am
Yeah, maybe have some bleed through or something going on with the switch. Nothing jumps out at me with your wiring, but the solenoid should not click at rest. The clicking is the spring energizing. If you've put a meter on it and don't see anything wrong, it is possible the solenoid is defective.
Sun Mar 12, 2017 10:09 am
Mon Mar 13, 2017 8:40 am
I'll pulled the power off the switch this afternoon....now that there is more light in the day....and see what happens.
Mon Mar 13, 2017 2:28 pm
18' x 54" Uncle J Custom w/ PD 36 FPR and Calen's Stage 2
Mon Mar 13, 2017 5:54 pm
Mon Mar 13, 2017 7:24 pm
