| Rpms http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70123 |
| Author: | estadalis [ Sat Mar 25, 2017 11:08 am ] |
| Post subject: | Rpms |
Just bought a rig guys. It has a 2010 36 prodrive on it. The tach on it went out and I ordered one this morning. Me and one other guy topped out at 22 mph in it. It's on a 17x48 x series. I'm really thinking I'm not getting the rpms I should be. Also, in gear when I idle, I have to feather the throttle to keep it from dying. It's just running at really low rpms. I don't want to mess with anything until the tach comes in, but after that how can I adjust the rpms? I'm running stock everything. I know this is probably blatantly obvious but this is my first sd. Thanks for any help |
| Author: | flint87 [ Sat Mar 25, 2017 11:46 am ] |
| Post subject: | Re: Rpms |
How's the prop? Sent from my iPhone using Tapatalk |
| Author: | Will C [ Sat Mar 25, 2017 11:47 am ] |
Could be a dirty carb or need a simple carb adjustment but good chance it needs a valve job or head gaskets as worse case scenario. This pic is your idle rpm screw. Shit pic i know. You might need to find someone to give it a checkup since you just got it |
| Author: | Will C [ Sat Mar 25, 2017 12:01 pm ] |
I will add that i recently saw 2 different bone stock prodrives that ran 23 wide open on an 1850 with a little weight. Yours isnt too bad but your shit idle has me thinking motor isnt healthy |
| Author: | estadalis [ Sat Mar 25, 2017 12:50 pm ] |
Once I get the tach out on I'll try to figure it out. If not I'll take it to prodrive. The guy had just gotten a 300 hour done on it from prodrive and it's at 360. New carb, etc. I checked compression when I bought it and I was running 130 psi out of both cyclinders. |
| Author: | Bug [ Sun Apr 02, 2017 1:46 pm ] |
Go find the post about bending the tab on the governor spring linkage, that solves the idle woes most of the time... |
