It is currently Sun Mar 29, 2026 8:56 pm
Reply to topic  [ 10 posts ]
 36 HP vanguard shaving heads ?
Post 36 HP vanguard shaving heads ?
Has any one had problems after shaving there heads .050 on a 36 HP big block vanguard ?
Like detnation or some other type of issues ?
Thinking about shaving mine .050 to get some more power out of the engine
also will the stock head gasket be fine or will it be best to use a copper head gasket
I know copper is better but is it nessary for this type of modification ?
Tue Aug 19, 2014 10:43 am
Post Re: 36 HP vanguard shaving heads ?
If u can find a copper gasket it's better but not necessary 50 thousandths depends on what other mods u havr
Sent from my iPhone using
Tue Aug 19, 2014 11:11 am
:arrow: Use stock gasket and you can go .060 you will be 185/190 psi run 93 octane you will be fine as long as you are using stock rods
Tue Aug 19, 2014 11:12 am
Shaved .055, stock gaskets, 190 psi on my tester w/ stock pistons and rods running 91 octane non-ethanol unleaded with no issues.
Tue Aug 19, 2014 11:47 am
Sorry I know this is an old thread, but how much speed could I pick up by shaving the heads on my 36hp vanguard?
Sat Apr 01, 2017 8:57 pm
By only decking the heads only you will get a noticably more stronger engine with just a little bit mre top end.
Sun Apr 02, 2017 10:05 am
So my motor would perform better with a load and out of the hole? And are there any cheap mods I can do to increase top end speed?
Sun Apr 02, 2017 11:20 pm
Mon Apr 03, 2017 4:42 am
Carb, Heads, and exhaust will wake that puppy up! What goes in needs more space to come out=torque and speed increase!
Tue Apr 04, 2017 8:22 am
Tue Apr 04, 2017 2:27 pm
