| gator tail 37 shutting off http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70153 |
| Author: | dirtydan [ Tue Mar 28, 2017 5:59 pm ] |
| Post subject: | gator tail 37 shutting off |
just wanted to throw up a little psa. i have a 2016 37 refi gator tail with about 50 hours on it and the last couple trips it would shut off on me. wasn't to sure what the problem was so i tried new fuel filters and tried to find a loose connection but no dice. i finally took the boat to the dealer and the mechanic showed me where the vibration had been causing the relays to short causing the whole wiring harness to heat up and go bad. i knew there was a recall but didn't figure there was much to it but, as it turns out there was. long story short they warrantied the whole wiring harness and performed the recall by adding rubber bushings to the relay panel making the situation right. so, keep an eye on your equipment. hope this helps |
| Author: | rubbinisracin [ Wed Mar 29, 2017 6:16 am ] |
| Post subject: | Re: gator tail 37 shutting off |
Hmm.. I wonder if mine is pre or post recall... I think I got it late April or Early may of 2016 |
| Author: | MaXXis85 [ Wed Mar 29, 2017 8:00 am ] |
There is NO official recall. It is a KNOWN problem. They will fix it if you have an issue. Just going in and say hey fix my harness wont work... But yes you issue is common bud. |
| Author: | Russ [ Wed Mar 29, 2017 9:41 am ] |
Work on that grammar, dude. Your attempt to help is totally lost in translation [FACE WITH TEARS OF JOY] |
| Author: | cb5331 [ Wed Mar 29, 2017 11:41 am ] |
He's just trying to fit in. |
| Author: | dirtydan [ Thu Mar 30, 2017 3:47 pm ] |
there's always a critic somewhere.... lol |
