It is currently Fri Jun 27, 2025 5:13 am
Reply to topic  [ 12 posts ]
 Keep Throttle Cable from Freezing!!!
Post Keep Throttle Cable from Freezing!!!
Here's how you boys can keep your throttle cables from freezing up.
Take a hyperdermic needle and fill it with anti freeze. Then shoot as much as will go into your throttle cable from the handle part of your throttle. Treat your cable once a year and you'll always be good to go.
Its not the cable that's freezing. Just the moisture that collects in it.
WC 1848 Bateau w/ 36 PD FPR
Fri Jan 08, 2010 9:22 am
Post Re: Keep Throttle Cable from Freezing!!!
thats a damn good idea
35 TX mud special stage 2 pushin a 1842 alweld
how much stick time does your keyboard have,prolly alot more than your damn boat
Fri Jan 08, 2010 10:29 am
Thanks Shafer. I was wonderin if a lil antifreeze would work or not.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Jan 08, 2010 10:56 am
Thanks TJ! Your so smart! I wish we could converse regularly on de phone ;)
Fri Jan 08, 2010 10:59 am
Fri Jan 08, 2010 11:58 am
Great News !!! 'Bout how much should we shoot off in there and what ifin' I spill ..... will it cause discolorations ?
Fri Jan 08, 2010 3:49 pm
Should we disconnect the throttle cable and turn it vertically so the fluid can run down the throttle cable?
1754 GT w/ 35 GTR Hoytafied
Fri Jan 08, 2010 3:51 pm
i figured there should be enough downward slope on the cable it would flow...just put it in till it fills up
Fri Jan 08, 2010 6:07 pm
get as much downward flow down the cable as possible, but wouldnt think youde need to disconnect the cable (i didnt).
brooks...shoot as much antifreeze in that sucker as you can. and dont worry bout spillin it. just a little extra for the neighborhood cats to take care of. :D
Sat Jan 09, 2010 1:56 pm
My cable froze saturday morning.. Got her freed then went hunting..
Remembered dis thread and used a cajun injecter and some Anti freez. I took the cable off the back of the carb and raised my handle where both ends were facing up. put a lil bit and work the cable back and forth. It takes a while cause my needle was too big , but it got the job done and my cable didnt freeze the next morning.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Mon Jan 11, 2010 9:04 am
Mine was frozen Sat too, so I went to look for some anti-freeze nd every swinging d*ck in the area bought all the anti-freeze( b?c they put water in their radiators all the time, etc>>>) so I had some subzero washer fluid with the deicer in it and that worked out great too.
HRCH Cajun Black "VOODOO" Magic
18x48 Center Console PD w/32PDHydro T&T; Hydro Reverse
"If I wanted any of your lip; I would pull down my zipper"
Mon Jan 11, 2010 11:27 am
I just drove around yesterday with mine freezing then thaw then refreeze. Kind of fun to never know if you can throttle up or down.
17' CAT 5 with 37 GTR
Mon Jan 11, 2010 12:27 pm
Users browsing this forum: No registered users and 97 guests
