more rpm for briggs 23hp
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70274
Author:  joshjc [ Mon Apr 17, 2017 8:39 am ]
Post subject:  more rpm for briggs 23hp
What all are you guys doing to get the rpms up on the small blocks and how high are you getting?
Author:  therocket95 [ Wed Apr 19, 2017 3:18 pm ]
Post subject:  Re: more rpm for briggs 23hp
Author:  flint87 [ Wed Apr 19, 2017 3:46 pm ]
Author:  joshjc [ Thu Apr 20, 2017 3:49 am ]
modded. I was just curious how high people were going
Author:  MaXXis85 [ Thu Apr 20, 2017 6:12 am ]
5k plus when the right parts are installed.
Author:  joshjc [ Thu Apr 20, 2017 10:46 am ]
that's about where I wanna be
Author:  redfish bandit [ Thu Apr 20, 2017 12:51 pm ]
Author:  goodblasson [ Thu Apr 20, 2017 3:36 pm ]
rev limiter 4700. Can almost turn 5K with a moderate load when rev limiter is unplugged. Motor is modded. I try not to run over 4300, trying not to blow up this motor. Over 400 hrs on modded motor.
Author:  huck Finn [ Thu Apr 20, 2017 9:17 pm ]
I like to cruise around the 4600 mark. Heavy load around 42-4300.
H Finn
Author:  nuccifish06 [ Fri Apr 21, 2017 8:40 am ]
Huck,
on my 23 can I get there with stock carb, manley valves, shimmed springs, high rev valve stems, thin head gaskets and timing key? Or do I need a cam some other stuff? and more $$$
Author:  SETx Longtail [ Fri Apr 21, 2017 1:02 pm ]
Keep digging in that wallet...
Author:  flint87 [ Fri Apr 21, 2017 1:12 pm ]
Author:  MaXXis85 [ Fri Apr 21, 2017 1:18 pm ]
Rods, pistons, carb, thin head Gaskets, Repair the factory heads from crushing, cam, and adjust timing if needed. It will be a hot rod mamma jama!
Author:  joshjc [ Mon Apr 24, 2017 10:44 am ]
ive got modded heads, mikuni carb, cam but im not done im going to go back into it and do crank,rods,and pistons end of summer just cant figure out if I want to do 2o or 30 over pistons yet,
