need new exhaust
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=7029
Author:  southtexaskillincrew [ Sun Jan 10, 2010 9:22 pm ]
Post subject:  need new exhaust
i have a 35hp go devil and my exhaust is rusting out.
does anyone have any info on a new exhaust thatll add some hp
Author:  deltaduckmaster [ Sun Jan 10, 2010 9:23 pm ]
Post subject:  Re: need new exhaust
Author:  Gigafowl [ Sun Jan 10, 2010 9:28 pm ]
GoDevil has a stainless version now for under 200 - same design
same performance and sound - but stainless...
Or the original is just over 100...
Author:  southtexaskillincrew [ Sun Jan 10, 2010 9:33 pm ]
did you feel like you gained any performance from the marsh mellow
Author:  Quackiller08 [ Sun Jan 10, 2010 11:00 pm ]
i have a stock 35 muffler and im lookin to get $45 if you need it asap pm me and ill get it shipped out
Author:  Gigafowl [ Sun Jan 10, 2010 11:20 pm ]
Click this link...
viewtopic.php?f=3&t=5748&p=59768
WestEndAngler did a whole thread on this Marshmellow Exhaust...
IMO - the exhaust only adds more noise but not much performance - but
if done with some carb changes will help get more from the carb,,,
When mine rusts too much - I'm going with the quieter SS stock one
from GD made for my 35 GDSD...
Author:  gecker [ Mon Jan 11, 2010 5:46 am ]
Take a look at this one:
http://www.mudboatmotor.com/html/exhaust_system.html
Thanks
Author:  deltaduckmaster [ Mon Jan 11, 2010 6:25 am ]
Author:  WestEndAngler [ Mon Jan 11, 2010 7:43 am ]
My MM is quieter than my stock exhaust.
Author:  southtexaskillincrew [ Tue Jan 12, 2010 7:08 am ]
have you had any expeirience with th gecker muffler
Author:  WestEndAngler [ Tue Jan 12, 2010 8:54 am ]
Author:  anotherred [ Tue Jan 12, 2010 9:00 am ]
Sounded "nasty". Is that in a good way, or bad? I've heard the crossover and liked the sound, just mainly wondering how the gecker sounds. Hard to tell from the videos posted.
Author:  WestEndAngler [ Tue Jan 12, 2010 9:24 am ]
Author:  richardb [ Tue Jan 12, 2010 10:11 am ]
Here is the Gecker Exhaust viewtopic.php?f=2&t=5006
some pics and video.
Hope that helps.
Author:  SP [ Tue Jan 12, 2010 8:42 pm ]
I have a Gecker exhaust on a pro drive, and I have been very happy with it. Gecker's muffler does not just sound good it helped my bottom end dramatically. I have never run the Marsh Mellow, but I have heard good things about it.
Author:  POKER1 [ Tue Jan 12, 2010 9:23 pm ]
Used my sound meter to get some readings from the stock and MarshMellow pipes to see what the difference was. All readings on the trailer and +/- 1db as the meter I have is not digital but accurate.
5' from exhaust tip / straight on
stock-78db @ 1000 rpms
MM-79db @ 1000 rpms
Stock-98db @ 4250 rpms
MM-98db @ 4250 rpms
3' from exhaust at seat/pod in boat
stock-83db @ 1000 rpms
MM-82db @ 1000 rpms
stock-100db @ 4250 rpms
MM-100db @ 4250 rpms
I kinda expected the MM to be a little quieter from inside the boat as the tip shoots straight back but it wasn't the case. However it shows that the MM has basically the same noise level as a stock pipe even though to the ear its seems quieter. And is much quieter than the Hopkins I had on it. Anything above 85db is considered damaging.
Author:  HuntingRDR [ Tue Jan 12, 2010 9:52 pm ]
Author:  POKER1 [ Tue Jan 12, 2010 10:14 pm ]
Don't know but it is louder.
Author:  WestEndAngler [ Tue Jan 12, 2010 10:21 pm ]
Thanks for readings Poker1
Author:  Quackiller08 [ Tue Jan 12, 2010 10:29 pm ]
i know WEA's MARSHMELLOW muffler wasnt near as loud as my single crossover
Author:  Brinkleydog [ Wed Jan 13, 2010 7:23 am ]
Author:  Glider [ Wed Jan 13, 2010 9:06 am ]
Thanks for the information posted about the MM exhaust. It backs up my testing results. I found that the readings from the drivers seat are more motor noise than exhaust noise. I made this monstrosity to get engine noise levels.
Author:  Crews [ Wed Jan 13, 2010 1:54 pm ]
what tha f*ck?!!! :shock: :lol:
Author:  slambin [ Wed Jan 13, 2010 2:04 pm ]
Author:  Glider [ Wed Jan 13, 2010 2:41 pm ]
That is six feet of ceramic fiber sound deadening. It was a collection of experimental exhausts that I haven't perfected yet. Very quiet quiet but completely impractical.
Author:  anotherred [ Wed Jan 13, 2010 3:25 pm ]
Glider, thought it was a super quiet exhaust for the longtail guys. :lol:
Author:  hismotherwasamudder [ Fri Jan 15, 2010 8:52 pm ]
Whatever exhaust you get I would not go with anything else except stainless for salt water. I had a regular GD exhaust on my GD35 and it rusted to crap. Now it was five years old and ran in nothing but salt water four of five times a week during the season, but i cleaned it every time and sprayed it down with corrosion-x.
My advice would go stainless on everything, even bolts and washers. And i had a very hard time getting my old exhaust off and broke a couple bolt and had to re-tap the hole. Now after about every two to three uses i am loosening the bolts and tightening them back in to be sure they don't seize up.
I also used never seize and haven't had a problem yet
Author:  b_coonass [ Fri Jan 15, 2010 9:10 pm ]
Author:  WES [ Fri Jan 15, 2010 10:03 pm ]
Author:  Swamp Wader [ Sat Jan 16, 2010 7:44 am ]
I would like to see the dB meter behind my hopkins :shock:
