It is currently Wed Apr 08, 2026 8:27 pm
[ 5 posts ] |
badams
 Exhaust Temp??
I have a 2008 PD 36 with mods..mikuni, head work ect. I gutted the can, and welded on a larger exhaust pipe. Im running lean.. does anyone know the exhaust, and head temps???
| Thu Apr 27, 2017 6:33 am |
MaXXis85
 Re: Exhaust Temp??
How do you know its lean? I would verify with an AFR meter.
| Thu Apr 27, 2017 7:23 am |
Will C
 Re: Exhaust Temp??
Or at minimum read the plugs after a wot run
| Thu Apr 27, 2017 8:05 am |
Will C
 Re: Exhaust Temp??
Also when you weld the exhaust tip on you need to reinforce that area with an extra layer. Ive seen 3 gutted stockers that the tips fell off from being very hot. When u gut one both exhaust flames are aimed right at the tail pipe area and will cook it
| Thu Apr 27, 2017 9:27 am |
BlueShamu
Joined: Mon Feb 06, 2012 6:13 pm Posts: 5605 Location: D'town, LA
 Re: Exhaust Temp??
| Thu Apr 27, 2017 7:02 pm |
[ 5 posts ] |
