It is currently Wed Apr 01, 2026 3:48 pm
Reply to topic  [ 16 posts ]
 Cutting out
Post Cutting out
Just added mikuni carb, heads, cam, roller rockers, and gutted exhaust, have trouble with the motor cutting out at 3200 to 3300. Running 167.5 main jet 30 pilot. Motor will hit 4700 no problem out of the water and in water cuts out. Anybody have any idea what could be causing this?
Sat May 13, 2017 6:02 am
Post Re: Cutting out
Make sure both cylinders are getting good spark and she isn't running on 1 cylinder.
Sent from my SM-G900P using Tapatalk
Sat May 13, 2017 8:23 am
I did forget to mention it has brand new coils, I changed them to be able to rule out ignition problems.
Sat May 13, 2017 9:42 am
It did flood through the overflow tube earlier so I'm thinking it's got something to do with the float or needle and seat
Sat May 13, 2017 9:44 am
Did you gap the coils correctly?
Sat May 13, 2017 10:02 am
Used a feeler guage and checked the old one then put the new one on and checked it till I got it
Sun May 14, 2017 5:50 am
What if the old ones weren't set correctly?
Sun May 14, 2017 9:05 am
Well I would assume they were since it ran good up until I had everything added
Sun May 14, 2017 10:42 am
What is the recommended gap to run? I mean the one coils were at .010 that's what I put them back on at
Sun May 14, 2017 10:45 am
Briggs spec is .005 gap. But if you are at .010 i doubt its your problem
Sun May 14, 2017 11:39 am
First of all 30 pilot Is a lot. 25-27.5 is a good start, But that is irrelevant to the current situation. Cutting out as in electrical spark stopping, or a fuel/air delivery issue? What needle and seat you have installed? If its not a 2.3 you will flood the carb.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Mon May 15, 2017 8:08 am
I have not checked the needle and seat. I bought the kit from the boat dr. As far as the cutting out once I hit 3200 to 3300 rpm it's like it's bouncing off of the rev limiter.
Mon May 15, 2017 8:59 am
Personally I'm wondering if the needle is sticking
Mon May 15, 2017 9:02 am
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon May 15, 2017 10:02 am
cdi or non cdi? External limiter?
Bayou Surface Drive
337-351-0362
Mon May 15, 2017 10:31 am
No I have not talk to Andy yet. And it is a cdi
Mon May 15, 2017 7:32 pm
