jessmanson44
 The right muffler
Have a GTR 35, with a marshmellow. Always have leaked. Thinking about a Q. Any suggestions?
Sent from my SM-G930V using Tapatalk
| Tue May 16, 2017 6:18 am |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
 Re: The right muffler
Is it leaking because of cracked welds or gaskets? I've had a marsh mellow for 3 years and have had zero issues with it.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
| Tue May 16, 2017 7:51 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
My BPS Q cracked (noticed the cracks) at 250 hrs, repaired it, 30 hrs later, leaking gasket, ordered Composite compression graphite gasket that someone suggested.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Tue May 16, 2017 8:11 am |
mucknaked
Leaking gaskets, since 2012. Just thought by now something else would be out there?
| Tue May 16, 2017 8:43 am |
Smoke
CB performance gaskets are the best i've found. order number 2801. They come 4 per pack because they are for a vw engine. Thick and reusable, at least twice as thick and the thickest gasket i've seen. Have you looked at the new BPS's exhaust? Looks good to me and if I ever start having issues with the mm i'm going with the new BPS Rapid R pipe? Supposed to be nearly as quiet as the Q but a deeper tone and has slip fit tubing with springs to help eliminate the cracking issues. Also made in the US with US stainless steel. http://www.backwaterperformancesystems. ... uct_id=424
| Tue May 16, 2017 9:27 am |
MaXXis85
cut slits in the slip flange.. Then put a clamp around the flange after to secure it. That is the majority of the leaking issue with a Marsh Mellow
| Tue May 16, 2017 9:43 am |
jessmanson44
Thanks guys
| Wed May 17, 2017 7:19 am |
jessmanson44
Where do you get those, CB performance gaskets
| Wed May 17, 2017 7:20 am |
brycecheramie
| Wed May 17, 2017 7:22 am |
50fps
Been running a Q for almost 7 yrs now with no issues.
| Wed May 17, 2017 8:07 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
Dan at Marshmellow now sells welded header pipes without the slip head flange
| Wed May 17, 2017 11:10 am |
mucknaked
Thank you guys so helpful.
| Wed May 17, 2017 3:18 pm |
