It is currently Thu Apr 02, 2026 3:47 am
Reply to topic  [ 12 posts ]
 The right muffler
Post The right muffler
Have a GTR 35, with a marshmellow. Always have leaked. Thinking about a Q. Any suggestions?
Tue May 16, 2017 6:18 am
Post Re: The right muffler
Is it leaking because of cracked welds or gaskets? I've had a marsh mellow for 3 years and have had zero issues with it.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Tue May 16, 2017 7:51 am
My BPS Q cracked (noticed the cracks) at 250 hrs, repaired it, 30 hrs later, leaking gasket, ordered Composite compression graphite gasket that someone suggested.
Tue May 16, 2017 8:11 am
Leaking gaskets, since 2012. Just thought by now something else would be out there?
Tue May 16, 2017 8:43 am
CB performance gaskets are the best i've found. order number 2801. They come 4 per pack because they are for a vw engine. Thick and reusable, at least twice as thick and the thickest gasket i've seen.
Have you looked at the new BPS's exhaust? Looks good to me and if I ever start having issues with the mm i'm going with the new BPS Rapid R pipe? Supposed to be nearly as quiet as the Q but a deeper tone and has slip fit tubing with springs to help eliminate the cracking issues. Also made in the US with US stainless steel.
http://www.backwaterperformancesystems. ... uct_id=424
1854 Prodigy Open
HDR/Stage 3 mods
Tue May 16, 2017 9:27 am
cut slits in the slip flange.. Then put a clamp around the flange after to secure it. That is the majority of the leaking issue with a Marsh Mellow
Tue May 16, 2017 9:43 am
Thanks guys
Wed May 17, 2017 7:19 am
Where do you get those, CB performance gaskets
Wed May 17, 2017 7:20 am
http://lmgtfy.com/?q=cb+performance
Refurbishing a Prodrive
Wed May 17, 2017 7:22 am
Been running a Q for almost 7 yrs now with no issues.
Wed May 17, 2017 8:07 am
Dan at Marshmellow now sells welded header pipes without the slip head flange
Wed May 17, 2017 11:10 am
Thank you guys so helpful.
Wed May 17, 2017 3:18 pm
