| The right muffler http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70419 |
| Author: | jessmanson44 [ Tue May 16, 2017 6:18 am ] |
| Post subject: | The right muffler |
Have a GTR 35, with a marshmellow. Always have leaked. Thinking about a Q. Any suggestions? Sent from my SM-G930V using Tapatalk |
| Author: | Smoke [ Tue May 16, 2017 7:51 am ] |
| Post subject: | Re: The right muffler |
Is it leaking because of cracked welds or gaskets? I've had a marsh mellow for 3 years and have had zero issues with it. |
| Author: | CypressCritter [ Tue May 16, 2017 8:11 am ] |
My BPS Q cracked (noticed the cracks) at 250 hrs, repaired it, 30 hrs later, leaking gasket, ordered Composite compression graphite gasket that someone suggested. |
| Author: | mucknaked [ Tue May 16, 2017 8:43 am ] |
Leaking gaskets, since 2012. Just thought by now something else would be out there? |
| Author: | Smoke [ Tue May 16, 2017 9:27 am ] |
CB performance gaskets are the best i've found. order number 2801. They come 4 per pack because they are for a vw engine. Thick and reusable, at least twice as thick and the thickest gasket i've seen. Have you looked at the new BPS's exhaust? Looks good to me and if I ever start having issues with the mm i'm going with the new BPS Rapid R pipe? Supposed to be nearly as quiet as the Q but a deeper tone and has slip fit tubing with springs to help eliminate the cracking issues. Also made in the US with US stainless steel. http://www.backwaterperformancesystems. ... uct_id=424 |
| Author: | MaXXis85 [ Tue May 16, 2017 9:43 am ] |
cut slits in the slip flange.. Then put a clamp around the flange after to secure it. That is the majority of the leaking issue with a Marsh Mellow |
| Author: | jessmanson44 [ Wed May 17, 2017 7:19 am ] |
Thanks guys Sent from my SM-G930V using Tapatalk |
| Author: | jessmanson44 [ Wed May 17, 2017 7:20 am ] |
Where do you get those, CB performance gaskets Sent from my SM-G930V using Tapatalk |
| Author: | brycecheramie [ Wed May 17, 2017 7:22 am ] |
http://lmgtfy.com/?q=cb+performance |
| Author: | 50fps [ Wed May 17, 2017 8:07 am ] |
Been running a Q for almost 7 yrs now with no issues. |
| Author: | pokey79 [ Wed May 17, 2017 11:10 am ] |
Dan at Marshmellow now sells welded header pipes without the slip head flange |
| Author: | mucknaked [ Wed May 17, 2017 3:18 pm ] |
Thank you guys so helpful. |
