fuel problems
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70453
Author:  duckaholic225 [ Mon May 22, 2017 7:55 am ]
Post subject:  fuel problems
2013 35 gtr I can run all day long half throttle but if you run wot it will run out of gas and die. changed all the fuel lines and ran it out of water wide open for 15 minutes with no problem. put it back in water and it did the same thing . any suggestions or ideas would be appreciated.
Author:  MaXXis85 [ Mon May 22, 2017 8:13 am ]
Post subject:  Re: fuel problems
Have you cleaned the carb? As in remove the carb, remove jets from bowl, clean jets, passages, and try again? IF not do so.
Author:  brycecheramie [ Mon May 22, 2017 8:26 am ]
Air leak in the fuel line?
Author:  CypressCritter [ Mon May 22, 2017 9:03 am ]
Have you tried pumping the primer bulb while running to see if it runs out of Fuel? If pumping Primer bulb keeps it running - air leak or fuel pump.
Author:  duckaholic225 [ Mon May 22, 2017 9:43 am ]
I cant find no leaks in the fuel line that is why I changed it and all the clamps. when left sitting a few days the bulb looks like it is collapsing not hooked up to the tank. I was wondering why it only does this in the water going wide open and it wont do it out of water ? If the carb was dirty you would think it would do this in or out of the water.
Author:  brycecheramie [ Mon May 22, 2017 9:48 am ]
You don't have a load on the motor when out of the water.
Did you pull the jets and clean them like Maxxis said?
Author:  Russ [ Mon May 22, 2017 9:52 am ]
Author:  MaXXis85 [ Mon May 22, 2017 12:17 pm ]
Author:  Joe Guide [ Mon May 22, 2017 5:50 pm ]
Greetings from N.C.
I had this same issue happen over a year ago.
I sent you a PM to explain what we did, and how we figured what was causing this issue in my MM.
Author:  sledhead26 [ Mon May 22, 2017 6:01 pm ]
Had the same problem on my old motor. Ended up being the fuel pump. Put an electric pump on it and solved the problem. Ran like a champ after that.
Author:  duckaholic225 [ Mon May 22, 2017 7:15 pm ]
Author:  MaXXis85 [ Tue May 23, 2017 5:23 am ]
Author:  sledhead26 [ Tue May 23, 2017 6:03 am ]
Author:  CypressCritter [ Tue May 23, 2017 7:33 am ]
Hmmmm! That is why even with an electric fuel pump always put a primer bulb inline so if the fuel pump(electric or pulse)fails you can always pump the carb bowl full of gas to get back. Yeah and if an EFI fuel pumps fails that doesn't work.(I wont think it would due to the higher pressure required)
Author:  MaXXis85 [ Tue May 23, 2017 8:34 am ]
Only thing is if you idle a lot... thos e pump will overpower the float at times and can flood the intake manifold with fuel.
Author:  duckaholic225 [ Wed May 24, 2017 12:51 pm ]
thanks for the tips guys but it turned out to be a bad ball valve in the primer bulb. I took the bulb out and I ran without it and it ran all day without a issue. the question now is why would you have a bulb on it except for pumping it if the fuel pump goes out?
Author:  MaXXis85 [ Wed May 24, 2017 2:30 pm ]
