| Texas Fresh 35 build http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70541 |
| Author: | Will C [ Sun Jun 04, 2017 10:10 pm ] |
| Post subject: | Texas Fresh 35 build |
I just finished this one up. Started as an overheated stocker. |
| Author: | Will C [ Sun Jun 04, 2017 10:11 pm ] |
| Post subject: | Re: Texas Fresh 35 build |
Block prep |
| Author: | Will C [ Sun Jun 04, 2017 10:13 pm ] |
Shortblock got fresh rings, polished factory pistons, new rodbolts, 308 custom cam and the wetgasket treatment , good case bolts |
| Author: | Will C [ Sun Jun 04, 2017 10:17 pm ] |
Working on heads, decked, welded, heavy deshrouding, ported, larger manleys. Pic is before seatwork and cleanup |
| Author: | Will C [ Sun Jun 04, 2017 10:23 pm ] |
Heads installed with 1.5 rollers and hd aluminum pushrods |
| Author: | Will C [ Sun Jun 04, 2017 10:27 pm ] |
Topped it off with a delta upper and a 42hsr. Broke im the cam today and changed the oil. Sounds excellent. Hoping to go test before the caddo run. |
| Author: | MaXXis85 [ Mon Jun 05, 2017 5:20 am ] |
You said larger Manleys. Intake and exhaust or intake only? |
| Author: | Will C [ Mon Jun 05, 2017 7:55 am ] |
Intake and exhaust are larger. |
| Author: | CypressCritter [ Mon Jun 05, 2017 8:02 am ] |
NICE! But I think it would look better on my GTR frame! |
| Author: | Will C [ Mon Jun 05, 2017 8:09 am ] |
Funny you say that. You need to hurry up and upgrade! I have a feeling this motor is going to be a little too much for a Go devil frame |
| Author: | SETx Longtail [ Mon Jun 05, 2017 9:16 am ] |
No cavitation plate. Interesting..... I'm assuming it helps in thick vegetation? |
| Author: | Will C [ Mon Jun 05, 2017 9:29 am ] |
Yea previous owner cut it off. It digs through shit pretty good. My only complaint is at north of 30 ive got to hold it down while im standing up so i wears me out running fast. Ive added a bit of length to tabs and it helped. Maybe im just getting older but being able to run wot while sitting down is appealing |
| Author: | SETx Longtail [ Mon Jun 05, 2017 9:51 am ] |
Too much powah!!! I'm not on your level lol. What are you doing for a prop on that machine? |
| Author: | cb5331 [ Mon Jun 05, 2017 10:10 am ] |
| Author: | Will C [ Mon Jun 05, 2017 10:25 am ] |
I lnow im goin to catch some shit over Drinkin koolaid. The prop is a stocker that is balanced and the picth brought up just a touch. 100hrs on it now. 36 tooth top pulley. Definitely not optimal. I was going to play the prop game but now thinking of just swapping frames. At least GT has proven props that work |
| Author: | MaXXis85 [ Mon Jun 05, 2017 12:34 pm ] |
| Author: | Will C [ Mon Jun 05, 2017 12:51 pm ] |
When im cutting the seats going bigger lets me "lay back" the angles and put more funnel into it |
| Author: | Will C [ Mon Jun 05, 2017 12:54 pm ] |
Also after i deshrouded i pushed the chamber to the gasket line by hand around the valves |
| Author: | MaXXis85 [ Mon Jun 05, 2017 12:59 pm ] |
| Author: | Will C [ Mon Jun 05, 2017 1:04 pm ] |
I feel ya on the 80/20 rule. Stock size just dosent let me do the valve job i like. Its also why i pushed out the chamber to make up for it. These exhaust valves are still smaller than what bps uses. Not that im comparing to them |
| Author: | MaXXis85 [ Mon Jun 05, 2017 1:24 pm ] |
Yeah everyone does there valve jobs a specific way. We all have opinions lol. Without them life would be bland. Keep up the good work. I've heard good that comes out of your shop. |
| Author: | Will C [ Mon Jun 05, 2017 1:39 pm ] |
Im a small shop like yourself. We have to be good to keep em going. If you come to caddo i will buy u a beer |
| Author: | MaXXis85 [ Mon Jun 05, 2017 1:43 pm ] |
| Author: | Russ [ Mon Jun 05, 2017 1:49 pm ] |
Will, he's been talking smack about you. Don't trust anything he says. Sent from my SAMSUNG-SM-G891A using Tapatalk |
| Author: | Will C [ Mon Jun 05, 2017 2:02 pm ] |
Thats all good too |
| Author: | Russ [ Mon Jun 05, 2017 2:14 pm ] |
Those things there...... I need an anchor for my kayak, hence me wanting you to bring them. Sent from my SAMSUNG-SM-G891A using Tapatalk |
| Author: | Will C [ Mon Jun 05, 2017 2:26 pm ] |
| Author: | Russ [ Mon Jun 05, 2017 3:32 pm ] |
Just so no one judges his work from this conversation, the heads we're talking about weren't something he worked on. They were someone else's screw up, and not as advertised upon purchase. Sent from my SAMSUNG-SM-G891A using Tapatalk |
| Author: | Will C [ Wed Jun 07, 2017 12:18 pm ] |
Something else i noticed with the gdsd frame today. I was giving the boat a little run time in our test pond. I got out and let my brother make a pass. From standing on the bank i could see when he hits it the back end of the boat lifts and nose shoves down. Its got to be part of how the gdsd prop shaft hits the water at an angle instead of the force being square with the bottom of the boat. Just another small reason im looking foward to running a different frame |
| Author: | MaXXis85 [ Wed Jun 07, 2017 12:20 pm ] |
yeah. The more parallel and lower you can get the motor the flatter the push will net the best lift for the hull. |
| Author: | CypressCritter [ Wed Jun 07, 2017 9:13 pm ] |
Will, come early to Caddo, and i will try out that build on my GTR, let you sunday how it rum! |
| Author: | boatguy [ Sat Jun 10, 2017 5:11 am ] |
