It is currently Sat Apr 04, 2026 8:43 am
Reply to topic  [ 15 posts ]
 Woodruff Key/ GTR clutch
Post Woodruff Key/ GTR clutch
Gents,
I'm reassembling my GTR's transmission. I wasn't the one who took it apart but it all seems to make sense on where to go. Only thing is I'm just not seeing where the woodruff key goes. I'm sure it's obvious, but can someone provide me a picture or talk me in to where it goes in regards to the shaft extension?
Thu Jun 15, 2017 6:44 am
Post Re: Woodruff Key/ GTR clutch
The key fits in the inside of the extension in the side that fits onto the crankshaft.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Thu Jun 15, 2017 7:30 am
Does it go right there?
Thu Jun 15, 2017 7:35 am
Yes
Thu Jun 15, 2017 7:37 am
That's where it goes, and also in the key on the crankshaft. Tap it together and bolt it all back up!
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Jun 15, 2017 7:54 am
I appreciate it. This would have been a ton easier if I had seen it come apart. I'm going to try and get step by step pictures both so y'all can tell me if I assembled it wrong, and so someone else in the future can see it done.
Lesson of the day yesterday, wear gloves when putting on antiseaze. I look like the tin man. My hands are silver today at work.
Thu Jun 15, 2017 8:10 am
Lol you can use wd-40 and then dawn dish liquid to get that shit off you hands!
Thu Jun 15, 2017 8:17 am
Thu Jun 15, 2017 8:27 am
So ends up I had an extra woodruff key floating around from the crank of my busted old engine. That's what had me messed up. I couldn't figure out where this thing went. Mystery solved.
Fri Jun 16, 2017 8:45 am
extra woodruff key? In the case?
Kool-Aid Brigade
www.southernfowler.com
Fri Jun 16, 2017 9:14 am
There is a small key that holds the timing gear onto the crank.
Bayou Surface Drive
337-351-0362
Fri Jun 16, 2017 10:47 am
Yeah if you look on that picture, there was a small slot where that semi circle woodruff key went. It was inside my old busted block.
Fri Jun 16, 2017 11:23 am
Y'all stay out of this. He's got it figured out now, with a nudge in the right direction from me. 8-)
Fri Jun 16, 2017 11:30 am
Fri Jun 16, 2017 2:45 pm
Back on the water thanks to some great help via phone and pm on here as well as digging through a lot of past posts and topics. Thanks gents!
Mon Jun 19, 2017 8:23 am
