| Didn't go as planned http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70670 |
| Author: | TheVoyager14 [ Fri Jun 23, 2017 9:11 pm ] |
| Post subject: | Didn't go as planned |
I wanted to share my experience from tonight.. I set aside a few minutes to check the valve lash and do a little routine maintenance. As usual I use a pencil to check for the piston at 1/4" below TDC. Dropped the pencil in and spun the prop a few strokes. I noticed something funny and I guess the pencil got in a bind and snapped in half down in the cylinder. Has anybody ever had this happen before? That was at 5:00 this afternoon. Needless to say several busted knuckles and a case of beer later everything was ripped down and now I'm back up and running! I wanted to share this as a token of gratitude to folks on this forum. I am a rookie mechanic and referred to many posts on here for torque specs and tips. Thanks MMT |
| Author: | cb5331 [ Fri Jun 23, 2017 9:20 pm ] |
| Post subject: | Re: Didn't go as planned |
Lesson learned; dont stick a pencil in your cylinders again. Sent from my SM-T710 using Tapatalk |
| Author: | Will C [ Fri Jun 23, 2017 9:22 pm ] |
Lol, when setting the valves, spin the engine in its normal rotation. Watch the valve open then close and slowly give engine another 1/4 turn. Set that valve then repeat for other valves. Once your done roll it through its rotation again and recheck .Another fellow called me a while back and broke a pencil off. No need to know where the piston is to set the valves |
