It is currently Fri Apr 03, 2026 11:17 am
Reply to topic  [ 14 posts ]
 35 HP Briggs gator tail starter not engaging flywheel
Post 35 HP Briggs gator tail starter not engaging flywheel
Ok I'm sure this has happened to a lot of people out there, but I'm new to the game..The past few times I've been out, occasionally when I hit the key to start it up, I hear the starter whine, and does not engage the flywheel..I shake the motor a little, and keep tapping the key and it will eventually catch and start it right up. I took it to mobile in November on a red fish trip, so it has seen a couple days of brackish water, but mostly fresh water in southern Indiana. didnt know if it was rust around the gear on the starter, or something getting ready to go wrong.just don't want to get stranded down stream..any suggestions?
Thanks
Mon May 29, 2017 11:56 am
Post Re: 35 HP Briggs gator tail starter not engaging flywheel
Try pulling starter or fan shroud and lube up the bendex. Probly a good idea to order a starter
Mon May 29, 2017 12:00 pm
Trust me. Order a new starter.
Check the voltage at the yellow wire on the solenoid.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Mon May 29, 2017 12:24 pm
The starter king has spoken ^^
Listen to him! :lol:
Mon May 29, 2017 12:51 pm
Seriously though, order a new starter. It could just be the solenoid (and likely is), could be voltage at that yellow wire (quite possible too), but from experience, it sucks when you're 6 miles from the landing and your starter goes boom when you turn the key, or doesn't do anything when at the landing at 430 am, or everything else goes kchunk after a nice, ear pleasing whirrrrr turned screech at 4300 rpms.....
Mon May 29, 2017 2:19 pm
Ok thanks for the responses..when you say Check voltage at yellow wire, what should I be reading?..and this is with the key on, or while cranking?
Thanks
Mon May 29, 2017 6:23 pm
When cranking. Above 12 volts.
Mon May 29, 2017 6:36 pm
Ok found a diagram, shows the yellow from the solenoid goes to the 4 pin I assume is on a relay..so I'm guessing I shouldn't read anything unless the key is turned?
Mon May 29, 2017 6:39 pm
So if less than 12volts, it's the solenoid
Mon May 29, 2017 6:41 pm
No, if less than 12volts, it's the wiring or battery or key switch or something before the starter.
Mon May 29, 2017 6:43 pm
Pulled starter...it was rusted up..from running in rain..cleaned with WD40...starts like a champ
Mon Jul 17, 2017 7:19 pm
Good job! Still outta order a backup :D
Mon Jul 17, 2017 7:23 pm
^ this man speaks truth.
Mon Jul 17, 2017 7:25 pm
Starters RARELY go bad.... But when they do.... they don't work LOL... Get a spare!
Tue Jul 18, 2017 5:46 am
