| DIY EFI MODS http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70728 |
| Author: | Full Throttle [ Mon Jul 03, 2017 3:56 pm ] |
| Post subject: | DIY EFI MODS |
I've installed a cam, and a few stage 1s on carb motors over the years. Been outta the game for a bit... Looking to order heads, exhaust and a controller. It's my first efi motor... Would like to try some custom heads instead of IM this go around... so how do I go about getting a controller? Is it just like installing a tune on a truck, meaning plugnplay? Who all is offering kits for this other than bps? Thanks |
| Author: | Quack N Stack [ Mon Jul 03, 2017 4:42 pm ] |
| Post subject: | Re: DIY EFI MODS |
Ive talked to delta about them just sending me the parts and doing it myself. They'll do it and send you everything you need including break in oil. I THINK for around $1600 is what they told me...for the level 3 (stage 2 equivalent). Might want to double check that though its been alittle bit since i called and asked. |
| Author: | Russ [ Mon Jul 03, 2017 5:04 pm ] |
Check with Marcus at bayou surface drives, and will at Texas mud motors. Also prodrive might offer the efi kits still from ecotrons. Sent from my SAMSUNG-SM-G891A using Tapatalk |
| Author: | JJDTodd [ Mon Jul 03, 2017 5:11 pm ] |
The controller is just a bypass that tells the ecu more fuel. Once installed it stays. Delta and Franklin's are offering tuned ecus now so you don't need the controller. Hit up Nick Peltier Sent from my SM-G928V using Tapatalk |
| Author: | Woodiebuster [ Mon Jul 17, 2017 5:10 pm ] |
Jacking this thread. I'm just getting into the efi game as well, what is involved in tuning a motor yourself? Do you have to have a air/fuel sensor or a computer to plug it into? Are there different levels of controllers for more fuel or is it just one self mapping controller? |
| Author: | MaXXis85 [ Tue Jul 18, 2017 5:54 am ] |
Fuel controllers work by piggybacking with your injectors and installing a ground wire. Then make fuel corrections. Basically you are altering the stock maps by adding a percentage of fuel more than the stock map to compensate. It is BEST to have an AFR meter to dual in the proper ratio to keep the best state of tune on the motor. |
