Is there such a thing as a 23hp cdi motor? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70803 |
Author: | BassmasterCia [ Sat Jul 15, 2017 8:37 am ] |
Post subject: | Is there such a thing as a 23hp cdi motor? |
Ive searched til i'm blue in the face and all the info i've found leads me to believe that all the 23's are non cdi. Everybody just talks about adjusting the governor to get more rpm or talking it out and installing a rev box. When I hit 4300 it sounds like i'm on an electronic rev limiter. No surging like its the governor and the arm doesnt actuate. When I had my 35 i pretty much knew what I had or could at least find the info on here. Info for the 23's is few and far between. Do they make 4750 coils for the 23's? Are they the same coils as the 35? |
Author: | Will C [ Sat Jul 15, 2017 9:06 am ] |
Post subject: | Re: Is there such a thing as a 23hp cdi motor? |
Stock spinngs? It might be floating the springs, it will sound like a rev limiter |
Author: | BassmasterCia [ Sat Jul 15, 2017 9:09 am ] |
At 4300? And yeah the whole thing is stock |
Author: | Will C [ Sat Jul 15, 2017 12:51 pm ] |
The pointed lobes on a stock cam float early. Same springs with no shims wil rev higher with an aftermarket cam due to a softer round nose cam. Although the correct springs and shims is politically correct and should be done |
Author: | Will C [ Sat Jul 15, 2017 1:18 pm ] |
Just to elaborate a few years back i had 35non cdi with a stock cam and fresh heads with new white springs. Motor would free rev to 4200 and i could hear them foating. Ran good for a year and i put a cam in it about midnight one night before heading to lake in am. I didnt swap springs or add shims. Free rev to 4600 before float. I bet your 23 has the older spings////:: and maybe there is a 23 cdi motor,,,, im not sure |
Author: | BassmasterCia [ Sat Jul 15, 2017 1:55 pm ] |
Interesting. Definitely something to think about. Im still curious if it could be cdi |
Author: | Will C [ Sun Jul 16, 2017 1:00 am ] |
If you post your model# and type# i will look it up |
Author: | BassmasterCia [ Sun Jul 16, 2017 3:16 pm ] |
Wouldnt let me send it in messenger |
Author: | MaXXis85 [ Mon Jul 17, 2017 6:04 am ] |
Valve float like Will C said. No CDI 23's |
Author: | Will C [ Mon Jul 17, 2017 7:51 am ] |
Verified |
Author: | BassmasterCia [ Mon Jul 17, 2017 4:52 pm ] |
I knew it damn sure didnt charge like a cdi motor. Thanks guys, appreciate it! |
Author: | BassmasterCia [ Tue Jul 18, 2017 4:26 pm ] |
Well come to find out they did make a cdi 23. Special order. Damn go devil. No diodes coming from the coils. And whats worse is its still just a 20 amp cgarger and has to be over 2500 just like a non cdi. Its like somebody ordered this motor and said lets make it as slow as possible so walking back when the battery dies doesnt seem like its taking so long... |
Author: | Will C [ Tue Jul 18, 2017 7:40 pm ] |
I apologize for any misleading info. The good news its Rare and must be woth a ton of money ![]() |
Author: | redfish bandit [ Tue Jul 18, 2017 7:45 pm ] |
So do you need a rev. box and new stock coils ? If so let me know got some sitting in the shop on the shelf |
Author: | BassmasterCia [ Tue Jul 18, 2017 9:55 pm ] |
Hell i still dont know for sure that its CDI. From the numbers on the motor it's not. From the fact that the wires coming off the coils dont have diodes its a cdi. It's an odd ball. Not sure if its priceless or worthless but at this point id rather it just be normal lol |
Author: | MaXXis85 [ Wed Jul 19, 2017 6:33 am ] |
This is a first for me bud... |
Author: | MaXXis85 [ Wed Jul 19, 2017 6:58 am ] |
Gabe, I received the engine coding. It is INDEED a CDI digital ignition with a 4350 rev limit. |
Author: | BassmasterCia [ Wed Jul 19, 2017 8:56 am ] |
Soo.. anybody wanna swap me some non cdi parts? |
Author: | Will C [ Wed Jul 19, 2017 9:04 am ] |
If you need to spin it higher I understand. Sometimes these motors are hard to start with added timing and compression due to non cdi. Maybe you can warm up your motor and it still start good. Prop it to 4300.. just a thought |
Author: | BassmasterCia [ Wed Jul 19, 2017 9:10 am ] |
Yeah i probably will. It starts great as it is. I probably wont actually change the ignition system until its the only limiting factor. I wanna be "Huck fast" and then some. |
Author: | Will C [ Wed Jul 19, 2017 9:22 am ] |
Author: | BassmasterCia [ Wed Jul 19, 2017 9:34 am ] |
Hey i got the same boat except mine is lighter. Ought to be able to do it right? Lol |
Author: | cripper [ Tue Mar 02, 2021 10:22 am ] |
Hey fellas. Sorry to revive an old thread. I have a 23 copperhead that I’m gonna put the bps carb kit on and I’m also confused about the cdi vs non cdi. Here’s a picture of my coils. Per bps description it’s non cdi but from what I’ve read on the forums it could be a cdi coil as there is no diode. Also the part number that’s stamped on he coil produces zilch in a parts search. Can somebody who’s in the know run my engine numbers? 3864470084-0084-G1 Thank you |
Author: | cripper [ Tue Mar 02, 2021 10:33 am ] |
When I put my engine code into vanguard it shows these are the part numbers for my coils... |
Author: | Russ [ Tue Mar 02, 2021 12:51 pm ] |
Call Will at Texas Mud Motors. He's playdd a good bit with those 23s. #CFFITR #mudmotor>physics |
Author: | cripper [ Tue Mar 02, 2021 4:21 pm ] |
Thanks Russ do you happen to have his phone number? |
Author: | kaptainkrash [ Tue Jul 20, 2021 9:27 am ] |
4700 cdi coils off of a 35 fit and work just fine on a 23 |
Author: | huck Finn [ Thu Jul 22, 2021 3:42 pm ] |
Author: | BassmasterCia [ Sat Aug 14, 2021 10:53 am ] |
Funny thing is I just decided to spend a little money on the little motor and went looking for part numbers to change out all the ignition stuff so I’m glad it got revived. Anybody have a good model and type number to order parts from? Last thing I wanna do is order a new flywheel, stator and coils and end up with the stuff I already have. Also does anyone have all the parts laying around to do the swap? |
