fireman1562003
Joined: Tue Jan 31, 2017 10:43 am Posts: 67 Location: Wylie Tx
 fuel relays
where can I order some fuel relays for 37efi gtr ? just need to keep extras in the boat
_________________ 1754 UNCLE J 37EFI GTR stage 2 Delta ,
| Thu Jul 13, 2017 5:18 am |
cb5331
 Re: fuel relays
Have you tried just the local auto parts store? They won't be able to look it up, but if you bring one in, I'd think they might have em.
If that don't work, just call maxxis. He can send you some.
| Thu Jul 13, 2017 8:28 am |
MaXXis85
 Re: fuel relays
$25 a pop from the Briggs & Stratton... I'm going to verift if its 1 or 2 per part number.
| Thu Jul 13, 2017 9:21 am |
cb5331
 Re: fuel relays
Damn, that's fucked up.
| Thu Jul 13, 2017 9:29 am |
MaXXis85
 Re: fuel relays
Its a micro relay BTW. There is a Parentheses (2) on the description.. so it my be 25 for the pair, as each harness has 2 relays..
| Thu Jul 13, 2017 9:34 am |
cb5331
 Re: fuel relays
Is there anything stamped on the relay? Post a pic, I'll see if I can find something.
| Thu Jul 13, 2017 9:47 am |
MaXXis85
 Re: fuel relays
| Thu Jul 13, 2017 10:36 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: fuel relays
M&M I sent u a text. I cant figure out why Briggs would want that much money for them cause they pretty cheap
| Thu Jul 13, 2017 11:14 am |
cb5331
 Re: fuel relays
I figured they would be less than $5. Kinda like the old coil "harness", that was nothing more than about 36 inches of 16 gauge wire with two $.04 diodes in line. Didn't they charge like $70 for that thing?
Mouser and digikey both have pretty good cross reference search engines for small electrical components like that. If there is anything stamped on the relay at all, I'm sure I can find a suitable replacement on the cheap. I really wouldn't be surprised if its something you can pick up at the local auto parts store either. Though it'll probably be 10-15 bucks going that route.
| Thu Jul 13, 2017 11:23 am |
pokey79
 Re: fuel relays
we found one at O'reileys for a a/c clutch that worked and it was 15$
| Thu Jul 13, 2017 12:05 pm |
cb5331
 Re: fuel relays
Sounds about right.
| Thu Jul 13, 2017 12:44 pm |
fireman1562003
 Re: fuel relays
thxs guys we found em !!!
| Sat Jul 15, 2017 5:44 am |
