It is currently Tue Mar 31, 2026 5:26 am
Reply to topic  [ 6 posts ]
 Worked stock carb?
Post Worked stock carb?
Was thinking of sending my heads,intake and stock carb out to Willey fast but was looking for feed back from guys who have had the stock carb worked and if it was worth the money or not. Motor has stock internals
Fri Aug 18, 2017 6:48 am
Post Re: Worked stock carb?
I get very good results with custom stock carb work. each builder uses different tricks
Fri Aug 18, 2017 8:37 am
Nick does a lot of work to the stock carbs. Bores the venture larger, thins throttle blades, thins shafts, drills jets larger for the additional flow. Its about 2/3 the cost of a mikuni, But most wont appreciate the work it takes to get a carb at that point.
Fri Aug 18, 2017 9:14 am
Fri Aug 18, 2017 2:12 pm
Yes
Fri Aug 18, 2017 2:44 pm
The carb Nick does, was put on a flowbench with and intake manifold bolted to a head. It flowed as much as an HSR42 with an unported PVT adapter.
Mon Aug 21, 2017 5:41 am
