| 23 mud buddy problems need help http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=71066 |
| Author: | Fuquabw2016 [ Fri Aug 18, 2017 5:45 pm ] |
| Post subject: | 23 mud buddy problems need help |
I'm trying to fix a buddy's 23 mud buddy it cranks and runs fine but soon as you trim it up or down it dies ? Like it does when you pull kill switch . Could it be broke wire grounding it out ? Anyone else had this problem ? |
| Author: | Darryle [ Fri Aug 18, 2017 6:34 pm ] |
| Post subject: | Re: 23 mud buddy problems need help |
Does sound like a short of some kind. Sent from my SM-G920V using Tapatalk |
| Author: | Fuquabw2016 [ Fri Aug 18, 2017 8:22 pm ] |
Figured it out someone that had it before him had one the trim wires hooked up to the wrong spot |
| Author: | Fuquabw2016 [ Mon Aug 28, 2017 9:03 pm ] |
This 23 hp vanguard engine someone installed a after market carb on it guy that I got it from said tach said it would rev up to like 7000 Rpms figured that's way to high . Question is what is it supposed to run and when they installed it think they removed governor where they supposed to do that and do I need to get a aftermarket rev limiter for it still has stock one ? Also when it was on the guys mud buddy frame it crank and ran fine outa the water but bogged way down when put prop in water ? Pretty sure both head gaskets around blow could that be the motors problem causing it to bog down ? |
