NEED SOME HELP!!older model gator tail w/cranking issues!!!
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=71106
Author:  magnum [ Thu Aug 24, 2017 2:56 pm ]
Post subject:  NEED SOME HELP!!older model gator tail w/cranking issues!!!
Hey all! I have an older model Gator tail tiller powered by a 35 hp Vanguard. Sometimes it starts :D , sometimes it just clicks and won't turn over :cry: . I thought it was the starter, so I replaced it and it still did the same thing :shock: . Next, I replaced the ignition switch, same problem :evil: . The clutch switch appears to be working properly. Any suggestions on what to try next?? Thanks in advance for your response!! :mrgreen:
Author:  brycecheramie [ Sat Aug 26, 2017 6:39 pm ]
Post subject:  Re: NEED SOME HELP!!older model gator tail w/cranking issues
Did you replace the solenoid on the starter?
What about your 12 volt wire going to the solenoid?
Author:  Russ [ Sat Aug 26, 2017 9:25 pm ]
Check the voltage on that yellow wire going to the starter solenoid, and charge your battery.
#TheGhostBoat
Author:  Will C [ Sat Aug 26, 2017 11:16 pm ]
Yep^^ low signal power on that yellow wire, unless the obvious battery connections are shit
Author:  magnum [ Fri Sep 01, 2017 7:30 am ]
Thank you all for your responses!! i checked the 12 volt wire to the starter and it was dead. turns out it was a corroded wire from the kill switch! Thanks again!
Author:  Will C [ Fri Sep 01, 2017 7:32 am ]
Glad you found it
