It is currently Thu Apr 02, 2026 7:24 am
Reply to topic  [ 4 posts ]
 Prodrive relay issue
Post Prodrive relay issue
Pressure washed the boat off and after it dried was spraying the motor and wires down with some WD40. When all hell broke loose red wire going to starter was a glowing and smoking the other wires got hot also. As fast as it happened it stopped key was off. Any suggestions on what to do other than rewire it and see what happens.
Dont criticize a farmer with your mouth full
Thu Aug 24, 2017 4:04 pm
Got everything rewired and put in a new relay. Now all I get is a click as I hit the switches. Is it possibly the pump motor has gone bad? How can I check you see if that is the issue?
Sun Sep 03, 2017 5:37 pm
Post Re: Prodrive relay issue
You need to verify good power and ground to the motor. If good then give motor a love tap to see if it wakes up
Sun Sep 03, 2017 7:38 pm
Good power and multiple love taps. Is there a more economical replacement than direct from prodrive.
Mon Sep 04, 2017 10:52 am
