It is currently Mon Apr 06, 2026 6:07 pm
[ 4 posts ] |
Toggle switch instead of PTO switch
banded-mallard
I'm drawing up a new control box with some new switches and I'm thinking about using a simple toggle for the clutch instead of the PTO switch. Much smaller, can get a 20a if needed. I think that gatortail uses a toggle for their clutch engagement if I remember, but is it wired directly or is it run through a relay? All of my switches are run through a 20a fuse, so if the clutch goes out, the fuse blows and doesn't wreck my switches. But just curious of any info about the toggle.
| Thu Aug 24, 2017 12:38 pm |
Will C
 Re: Toggle switch instead of PTO switch
They are wired straight with no relay.
| Thu Aug 24, 2017 1:07 pm |
cb5331
They're very low current. Want to say less than 5amps when I measured, but it's been a while. Either way, a 20a toggle switch should be more than sufficient.
| Thu Aug 24, 2017 1:16 pm |
banded-mallard
Good deal and the inline fuse will protect it. I could go DTST on / off switch and still keep the start interlock
| Thu Aug 24, 2017 1:18 pm |
[ 4 posts ] |
