jpalma77
Joined: Thu Jun 04, 2015 7:58 am Posts: 20 Location: Rosemount, MN
 Prodrive 36 wont rev over 4000
I am completely new to Surface drive motors and have been lurking around this site for months learning lots of stuff.
I just picked up a 2005 Prodrive 36 with only 130 hours on it. It has the marshmellow exhaust and a mikuni 42mm carb. I am not sure if it has an internal upgrades but just running in my garage the revs will stop exactly at 4000.
From what I found on this site it should be a few hundred more? Does it have a rev limiter?
I also found the Mikuni manual but looking for a little more insight on how to get my revs up.
Thanks, Josh
| Tue Sep 26, 2017 6:45 am |
dead animal
 Re: Prodrive 36 wont rev over 4000
1. look at carb. 2. watch throttle cable move as you twist the throttle. 3. adjust cable so it gives u more rpm's. [usually a screw on the carb allowing the cable to move more] 4. adjust it till the valves rattle, then back off a tad. 5. enjoy
former owner probly adjusted the throttle to stop at 4000rpm's so the motor would stop blowing up. u probly ought to leave it there.
| Tue Sep 26, 2017 6:56 am |
jpalma77
So 4000 doesn't seem low? I was reading guys were going up to 4600-4700 i just want to make sure I get everything I can out of the motor but I don't want to be at a shorter life for the internals. Thanks for the reply.
| Tue Sep 26, 2017 7:02 am |
jpalma77
Also is there a purpose for this chain on a shaft? It is rubbing on my aluminum on the engine and will definitely wear before the bolt does.
| Tue Sep 26, 2017 7:04 am |
banded-mallard
| Tue Sep 26, 2017 7:38 am |
Will C
This problem seems odd. Out of water with a mikuni even 1/4 throttle should rev to the moon. What does it sound like when at max rpms? Video?
| Tue Sep 26, 2017 7:54 am |
jpalma77
Sounds good, yeah I will cut it off it was vibrating like crazy and with it hitting the engine its gone, on the carb I will look and make sure I have full travel. It sounds good at full throttle it isn't bouncing around or hunting at all. I will try and get a video tonight.
| Tue Sep 26, 2017 8:07 am |
cb5331
| Thu Sep 28, 2017 12:46 pm |
Russ
watch the slide instead, not the throttle cable. if it doesn't open fully, then throttle cable needs adjustment.
| Thu Sep 28, 2017 1:51 pm |
dead animal
| Thu Sep 28, 2017 2:32 pm |
Russ
or, just don't rev it up in neutral, or get a rev limiter. top speed is irrelevant to me, but I can load up my boat and still plane out, which a stock motor won't do. it's not for everyone, but neither is stock and speed isn't always the reason.
| Thu Sep 28, 2017 4:14 pm |
dead animal
got damn yall is some touchy mutherfukers.
| Thu Sep 28, 2017 5:09 pm |
Russ
nah. just pointing out the cat can be skinned different ways.
| Thu Sep 28, 2017 5:37 pm |
Will C
"Speed is irrelevant to me" russ says.  you liar
| Thu Sep 28, 2017 8:46 pm |
MaXXis85
| Fri Sep 29, 2017 5:27 am |
jpalma77
So after looking at my carb it looks like it isnt a mikuni unless it is an older one or something. I dont think it is a stock one? I was also looking at my idle rpm and its at about 1600 seems way to high.
Anyone recognize this carb?
From other threads looks like 1200 is a pretty good idle speed?
| Sun Oct 01, 2017 6:38 pm |
Will C
Thats a stock carb with a different flavor airfilter adapter. So at 4k its sitting on the governer
| Sun Oct 01, 2017 7:02 pm |
banded-mallard
| Mon Oct 02, 2017 9:05 am |
50fps
| Mon Oct 02, 2017 1:10 pm |
MaXXis85
Judging by that carb you have a 32 PD NOT a 36.....
| Tue Oct 03, 2017 6:57 am |
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
_________________ Phowler Extreme 1848 with 36PDFPR
| Wed Oct 04, 2017 3:09 pm |
